Servo Driver Interface PCA9685 Not showing on PI
by pinkstond on Tue Dec 11, 2012 11:54 pm
I have followed the tutorial for this product and the Raspi to no avail. The problems seems to be that the Pi is not picking up board. Whenever I run
i2cdetect -y 0
I don't see any devices, same is true for "1", but I'm running the first revision of the pi.
The servo board as the Green LED lit on it, and the SDA and SCL are hooked up to the corresponding labeled headers on the Adafruit prototyping board for the Pi. I am running Raspbian.
root@MaxxAir:~/Adafruit-Raspberry-Pi-Python-Code/Adafruit_PWM_Servo_Driver# i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@MaxxAir:~/Adafruit-Raspberry-Pi-Python-Code/Adafruit_PWM_Servo_Driver# i2cdetect -y 0
Any help would be mucho appreciated. Thanks!
pinkstond
Re: Servo Driver Interface PCA9685 Not showing on PI
by adafruit_support_bill on Wed Dec 12, 2012 7:20 am
Can you post a photo showing your soldering & connections?
by pinkstond on Wed Dec 12, 2012 11:30 am
None of the contacts are touching. The solder job was pretty straight forward and I didn't have any snags.
pinkstond
by adafruit_support_bill on Wed Dec 12, 2012 12:05 pm
The solder looks great. But where do all those wires go? Post a photo that shows both ends of the connections.
by pinkstond on Wed Dec 12, 2012 12:34 pm
Well, I brought the servo board into work with me today so I could work on it / check it out with a different pi (doesn't have proto shield) On that note the wires are going directly to the GPIO header on my company's pi. Once I find the results of testing it on the pi at work I will post my findings.
pinkstond
by pinkstond on Wed Dec 12, 2012 2:56 pm
Ok, I did get it to work properly on the Pi at work. So that eliminates the Servo board and wiring. I'll do some more research when I get home and try to eliminate more factors...
pinkstond
by pinkstond on Thu Dec 13, 2012 9:02 pm
Ok plugged into my home pi I am getting this when I run i2cdetect:
00:          03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
When I unplug the servo board I get all zeros. Any ideas?
pinkstond
by adafruit_support_bill on Fri Dec 14, 2012 7:13 am
Try wiring direct to the GPIO header like the one at work. Maybe there is something wonky on your proto-board.
by pinkstond on Sat Dec 15, 2012 12:16 am
Hrm nope same result. Hope something didn't happen to the servo board between work and home. Anything else I can check from home?
pinkstond
by adafruit on Sun Dec 16, 2012 1:59 pm
not sure what it could be but if it works on one pi and not the other, its not the servo board itself - make sure you're wiring up exactly the same!
by pinkstond on Mon Dec 17, 2012 11:43 am
Back into work today, decided to try it again on the work Pi. It's doing the same thing as the home pi now.
I have transported it in an anti static bag, not for sure what happened. Is it possible to ship it back to you guys have have it tested or something?
pinkstond
by adafruit_support_bill on Tue Dec 18, 2012 8:44 am
Can you post a photo showing all your connections?
by pinkstond on Tue Dec 18, 2012 12:47 pm
Now I'm not an expert by any means at some of this stuff, but I'm not exactly a noob either. I've used the pi and various other sensors and relays to automate a few things in the factory where I work. So I am familiar with basic trouble shooting and how to hook things up, process of elimination etc.
Not saying that I'm not open for suggestion, if you can think of something I am missing here, let me know.
As of right now, 2 different raspberry pis and the same result with the servo board.
I also read somewhere, a user with a Raspy Juice had a similar problem and it had to do with the firmware on the raspy juice.
pinkstond
by adafruit_support_bill on Tue Dec 18, 2012 1:03 pm
We have lots of these out there that are working fine with the Pi, but If you can post a link to that we can check out that angle.
by pinkstond on Tue Dec 18, 2012 1:08 pm
http://fishpi.org/forum/viewtopic.php?f=17&t=327&start=30#p1211
I'm not doubting for one second that these don't normally work. However, it is possible there is something wrong with it. That's why I offered to send it to you guys to check out. I'm fairly confident at this point it's the board.
pinkstond
