Adafruit 16-Channel Servo Driver smbus not defined
by nonlinearmind on Mon Dec 17, 2012 3:34 pm
I'm trying to get a Servo motor running using the tutorial.
I've changed the smbus settings for the RPi revision and keep getting the following error from line (30) that I changed in Adafruit_PWM_Servo_Driver.py
self.i2c = Adafruit_I2C(address, bus=smbus.SMBus(1))
NameError: global name 'smbus' is not defined
What am I doing wrong??
nonlinearmind
Re: Adafruit 16-Channel Servo Driver smbus not defined
by adafruit_support_bill on Tue Dec 18, 2012 6:41 am
Did you install the smbus library?
http://learn.adafruit.com/adafruit-16-c ... it-library
Before you start, you'll need to have the python smbus library installed, run apt-get install python-smbus
by nonlinearmind on Tue Dec 18, 2012 11:55 am
I had it installed. Here's what I get back when I run Servo_Example.py:
pi@raspberrypi ~/Adafruit-Raspberry-Pi-Python-Code/Adafruit_PWM_Servo_Driver $ sudo python Servo_Example.py
File "Servo_Example.py", line 12, in <module>
pwm = PWM(0x40, debug=True)
File "/home/pi/Adafruit-Raspberry-Pi-Python-Code/Adafruit_PWM_Servo_Driver/Adafruit_PWM_Servo_Driver.py", line 30, in __init__
nonlinearmind
by adafruit on Mon Dec 24, 2012 1:29 pm
can you try again with a fresh copy of the git repository? we cant reproduce this...
