Adafruit 16-Channel Servo Driver error
by nonlinearmind on Thu Dec 20, 2012 5:02 pm
I'm trying to get a Servo motor running using the tutorial. I've followed all the steps and have successfully run sudo i2cdetect -y 1
, but when I try to run the servo example, I get this error.
pi@raspberrypi ~/Adafruit-Raspberry-Pi-Python-Code/Adafruit_PWM_Servo_Driver $ sudo python Servo_Example.py
File "Servo_Example.py", line 12, in <module>
pwm = PWM(0x40, debug=True)
File "/home/pi/Adafruit-Raspberry-Pi-Python-Code/Adafruit_PWM_Servo_Driver/Adafruit_PWM_Servo_Driver.py", line 30, in __init__
self.i2c = Adafruit_I2C(address, bus=smbus.SMBus(1))
NameError: global name 'smbus' is not defined
nonlinearmind
Re: Adafruit 16-Channel Servo Driver error
by adafruit_support_bill on Thu Dec 20, 2012 6:06 pm
Have you installed the smbus library?
Before you start, you'll need to have the python smbus library installed, run apt-get install python-smbus
http://learn.adafruit.com/adafruit-16-c ... it-library
by nonlinearmind on Thu Dec 20, 2012 7:14 pm
Yes, I've installed it and change the smbus line in Adafruit_PWM_Servo_Driver.py to
I've also run sudo i2cdetect -y 1 and gotten the same result as in the tutorial.
nonlinearmind
by adafruit_support_bill on Fri Dec 21, 2012 7:11 am
cron
