Occidentalis v0.2 uses 256 of 512
by beeman on Fri Dec 28, 2012 12:19 pm
The command 'free -m' reports total memory size of 230 rather than about 480. The download, md5, image install, first boot, and configuration went just like the adafruit tutorials for Occidentalis v0.2 (Great)!! At the configuration for memory_split, I selected 16m for GPU since we do not need graphics for instrumentation of bee hives. It appears that not all the 512mb of ram is being used by the kernel configuration. How can I change the boot configuration to recognize all the ram? :- )
BeeMan, instrumentation for research
beeman
Re: Occidentalis v0.2 uses 256 of 512
by Twi7ch on Fri Dec 28, 2012 2:34 pm
To harness the full 512MB run the following command:
sudo apt-get update && sudo apt-get install raspi-config libraspberrypi*
Followed by
sudo reboot
Twi7ch
by beeman on Fri Dec 28, 2012 3:12 pm
THANK YOU very much. Updating most of the files in the /boot directory (including the kernel) worked just fine.
Then I added a new line "gpu_mem=16" to the end of the /boot/config.txt file for the minimum graphics memory.
Now the command "free -m" shows a total of 486mb available.
The plan is to add environmental sensors to monitor bee hives for chbr.org. Thanks again :- )
beeman
by Twi7ch on Fri Dec 28, 2012 3:21 pm
No problem. Good luck with the project :D
Twi7ch
