C library for Adafruit RGB Negative 16x2 LCD+Keypad Kit for Raspberry Pi
by JanBlomqvist on Mon Dec 31, 2012 5:12 am
Hi, I wonder if there are any C libraries or any C code for the Adafruit RGB Negative 16x2 LCD+Keypad Kit for Raspberry Pi. The software on the Git hub is just Python.
/Jan
JanBlomqvist
Re: C library for Adafruit RGB Negative 16x2 LCD+Keypad Kit for Raspberry Pi
by adafruit on Wed Jan 02, 2013 9:08 pm
At this time we have only Python - there's a lot of dependencies that would be required to make it work in C, its not an easy task to port!
by FunkyELF on Thu Jan 03, 2013 11:35 am
JanBlomqvist wrote:Hi, I wonder if there are any C libraries or any C code for the Adafruit RGB Negative 16x2 LCD+Keypad Kit for Raspberry Pi. The software on the Git hub is just Python.
/Jan
If you want to use it from C... calling Python code from C is pretty easy.
You'd just initialize a Python interpreter, instantiate a Adafruit_CharLCDPlate object. Keep it global for simplicity.
Then you can write C function wrappers that call the clear, message, and backlight functions on the the Adafruit_CharLCDPlate object.
Not a native C library, but if you want to be able to control it via C code, that'll work.
FunkyELF
by JanBlomqvist on Fri Jan 04, 2013 7:01 am
FunkyELF wrote:If you want to use it from C... calling Python code from C is pretty easy.
Thanks for the idea, but I had honestly hoped for complete C libs, anyway, I'll take this in account when I plan my coding, I need to think things over before I jump all over it.
/Jan
JanBlomqvist
