trouble setting up i2c
petert1
Post by petert1 »
I followed the steps in Lesson 4 . GPIO Setup but can not get the bus to work.
My R Pi is 512MB Model B with mounting holes and the 2012 /09/18 distro.
I have a MCP23008 connected per the GPIO Expander project with the Cobbler
Here is what I get at the terminal when looking for connected devices :
i2c-tools is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 168 not upgraded.
pi@raspberrypi / $ sudo i2cdetect -y 1
Error: Could not open file `/dev/i2c-1' or `/dev/i2c/1': No such file or directory
pi@raspberrypi / $ sudo i2cdetect -y 0
Error: Could not open file `/dev/i2c-0' or `/dev/i2c/0': No such file or directory
any suggestions?
Re: trouble setting up i2c
Post by adafruit »
are you using occidentalis?
petert1
Post by petert1 »
Not using occidentalis.
Using 2012 - 09 - 18 - wheezy raspberian.
I plan to get occidentalis with my next order as it seems appropriate for the things I have in mind.
Exercise 4 referred to 2012-10-28 Raspberian so I was hoping it might work with what I have.
petert1
Post by petert1 »
I switched to occidentalis and it all works fine.
Thanks for the tip.
electrictom
Post by electrictom »
Just for the record, I had a similar problem setting up the i2c communication on wheezy just the other day. I ran across a website (http://www.skpang.co.uk/blog/archives/575) that explained that on the new Raspbian distro, the i2c driver is installed but disabled. What you can do is just edit the file responsible using the following unix command:
sudo nano /etc/modprobe.d/raspi-blacklist.conf
Then comment out the i2c line (below) by putting a # in front (you can do the same for the spi line if you use that):
#blacklist i2c-bcm2708
It worked fine for me.
o0flatus0o
Post by o0flatus0o »
I had a similar issue as well. I am running Raspian "wheezy" and after following all the instructions I was still getting the error. I issued the following command and it seemed to solve my issue. Not sure if this was the "correct" thing to do though.
"sudo mknod /dev/i2c-0 c 89 0"
