Box for raspberry pi with adafruit LCD keypad
Talk about Adafruit Raspberry Pi® accessories!
Postby merald » Fri Jan 04, 2013 10:36 pm
I searched the net and cant find a case for raspberry pi with use of a adafruit with keypad like this one:
https://www.adafruit.com/products/1115
Is there any out there?
merald
Re: Box for raspberry pi with adafruit LCD keypad
Postby Twi7ch » Sat Jan 05, 2013 2:03 am
I've also asked this question and the answer is no. It is apparently a popular request so they probably have something up on the drawing boards.
Twi7ch
Postby adafruit_support_bill » Sat Jan 05, 2013 7:00 am
This is a very popular request and we are actively looking into it. No ETA.
Postby merald » Sun Jan 06, 2013 5:57 am
Ok, yea it falls very naturly if you should use the display accessory :wink:
merald
Postby matt-adafruit » Sun Jan 06, 2013 4:08 pm
What would you look for in a display faceplate or bezel? A library for OpenSCAD (or STL models) to combine with another model you are making, or a standalone faceplate with mounting points? This is something am looking forward to trying in my free time to see what I can produce and share!
matt-adafruit
Postby hiroshijack » Tue Jan 22, 2013 11:28 am
I would like to see you simply create a plate for the pibow. The pibow was meant to be modular, at least according to the creator's website. It was meant to have different plates for different uses, so why not create one for this? It would replace the top cover plate, and would have the screw holes for the 16x2 LCD display (or any other small LCD display). If these holes did not line up with the screw holes on the pibow enclosure, then simply enlarge the plate a little, and raise the screw holes so that both screw hole sets can be used. To make it cheaper in terms of materials, leave a hole through the center of this, so people connect the pins directly to the raspberry pi with a short cable or stacking header. You could sell it in different colors, make it out of acrylic, and use your laser cutter to manufacture it, just like the pibow. You could sell it as a kit (with a small piece to connect the LCD and RPI, and alone (for people who wish to use the USB backpack). I have a crystal pibow, and this seems like a better idea than buying a 16x2 LCD stand made out of acrylic from one of your suppliers. Please also make one for your 4x4 keypad (which does not have screw holes, so you would probably use the same design as the vesa board mount), as I think a RPI with embedded buttons would be very nice. It could even function as a lock (with password required to boot).
hiroshijack
Postby hiroshijack » Tue Jan 22, 2013 11:41 am
Should it prove costly to make a multi-level plate, you could just use washers to adjust the height.
hiroshijack
Postby stulevine » Fri Jan 25, 2013 4:53 pm
Well, for me, I just received my Adafruit Pi Box with the full intention of keeping my Blue & White LCD Pi Plate attached. In fact I really like the setup:
stulevine
Postby gourou » Fri Feb 01, 2013 10:18 am
We're working on making the extension kit for the pibow, as the LCD is such a useful companion :)
Here's an idea of the work in progress:
gourou
Postby hiroshijack » Fri Feb 01, 2013 2:42 pm
That looks absolutely wonderful.
hiroshijack
Postby Twi7ch » Fri Feb 01, 2013 2:43 pm
That looks awesome. Great work!
I'm just using the clear case and elastic bands.
Twi7ch
Postby adafruit » Wed Feb 06, 2013 11:32 pm
Please note from now on all the kits will have the buttons on the right side!
Postby gourou » Thu Feb 21, 2013 2:35 pm
Noted, and thanks for the heads up :-)
Patient Bear will be ready when you are.
http://imgur.com/r/pics/lwYB3
gourou
Return to Adafruit Raspberry Pi® accessories
Users browsing this forum: No registered users and 2 guests
New Products [107]
More Dev Boards[31]
Components & Parts[70]
LEDs[111]
Cables[62]
