Static IP address in Occidental
by bayesp on Tue Jan 15, 2013 8:24 am
Hi
does anyone know how to set a static IP address in Occidental. I plan to use web IDE without connection to a router (Ad-Hoc) so no DHCP server involved.
Paul.
bayesp
Re: Static IP address in Occidental
by adafruit on Tue Jan 15, 2013 6:00 pm
it would be the same as any linux computer - but we're not sure how to do that. any debian linux static IP tutorial should work :)
by jimmayhugh on Thu Jan 24, 2013 10:14 am
Modify the file /etc/network/interfaces and add the static IP, mask and gateway addresses. Pretty simple actually.
jimmayhugh
by adafruit_support_rick on Wed Sep 04, 2013 11:40 am
jimmayhugh is correct. The default etc/network/interfaces file looks like this:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
        wpa-ssid "myssid"
        wpa-psk "mypassword"
You want to comment our the line "iface eth0 inet dhcp", and add the static iface "stanza". Substitute your address, netmask, and gateway for the ones I show here:
auto lo
#dhcp configuration of eth0
#iface eth0 inet dhcp
#static configuration of eth0
iface      eth0 inet static
    address   192.168.1.127
    netmask   255.255.255.0
    gateway     192.168.1.1
auto wlan0
allow-hotplug wlan0
        wpa-ssid "fios63"
        wpa-psk "fepulatorfepu"
After you edit the file, you don't actually have to reboot (if you don't want to). You can apply the new settings by issuing the following 2 commands:
sudo ifdown -v "eth0"
sudo ifup -v "eth0"
(NOTE: don't do this if you're logged in via ssh or vnc - your network connection will go away!)
