Winter Storm Juno: Blizzard! ORDERS NOT SHIPPING TODAY. All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
16 Channel Servo Driver
by DanCardin on Sat Jan 19, 2013 11:54 pm
Howdy, so I just soldered the servo driver together today, and can't seem to get this a-working. Ive attached what my circuit looks like. The only hard thing to see is the cobbler end of the ground wire, which is in fact in the ground (third pin up). So when i plug in the cobbler ribbon cable, it lights up the power led, and when i plug a servo into the first (or any) slot, and then plug plug in the v+, the servo jumps a bit. But running Servo_example.py doesnt move it at all. I get no errors from the script, and it is showing up in 0x40.
If I'm wiring it wrong, I can't see how. and the lack of errors is also making my problem elusive to me.
DanCardin
Re: 16 Channel Servo Driver
by adafruit_support_bill on Sun Jan 20, 2013 7:46 am
Where is the V+ coming from? Make sure that you connect the ground from that supply also.
by DanCardin on Sun Jan 20, 2013 11:22 am
v+ is from the power blue thing to the ac wall adapter
DanCardin
by adafruit_support_bill on Sun Jan 20, 2013 11:28 am
OK, so the ground will be connected too.
What code are you using? Make sure you plug the servo into the port that matches your code. (the wiring diagram in the tutorial is different).
by DanCardin on Sun Jan 20, 2013 12:50 pm
Im using the Servo_example.py with the suggested changes that they said to do if you have a rev2 (because it gives me errors when I change it back). And Im putting the motor in 0, though ive tried all of them. all that happens is that the motor jumps a little when the pins touch, but that's it.
DanCardin
by garyns on Sun Jan 20, 2013 10:46 pm
I am experiencing exactly the same issue (servo jumps at power-on, no errors when running script), and have double checked all the wiring and servo port, including trying different ports.
Did you ever get a solution to this problem?
Gary.
garyns
by garyns on Sun Jan 20, 2013 10:57 pm
Just go it working - totally powered the rPI (not just rebooting) and board. At restart it just worked.
garyns
by DanCardin on Sun Jan 20, 2013 11:25 pm
Thanks! that never even occurred to me, haha
DanCardin
