Occidentalis v0.2, WebIDE, and Tkinter
by ptdecker on Sat Jan 26, 2013 7:28 pm
Hello!
I have installed the WebIDE on Occidentalis v0.2 on my Raspberry Pi. Everything seems to be working fine (nice tutorials!).
However, I'm trying to run the simple program below using the Tkinter GUI libraries:
# File: hello1.py
from Tkinter import *
# Create root window
root = Tk()
root.title("My First Raspberry Pi GUI")
root.geometry("200x85")
# Create a frame
app = Frame(root)
app.grid()
# Create a button in the frame
bttn1 = Button(app, text = "Click me!")
bttn1.grid()
# Start main loop
root.mainloop()
And, I receive the following error when I run it:
webide@raspberrypi /usr/share/adafruit/webide/repositories/my-pi-projects/Hello_World $ sudo python hello1.py
  File "hello1.py", line 7, in <module>
    root = Tk()
  File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1688, in __init__
    self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
_tkinter.TclError: no display name and no $DISPLAY environment variable
I have tried to manually set the $DISPLAY environment variable to the LXDE session running off the HDMI port on the Raspberry PI itself whose $DISPLAY environment variable I confirmed is ':0.0' but had no luck.
Any ideas? Is Occidentalis and the WebIDE incompatible with Tkinter?
P. Todd
ptdecker
Re: Occidentalis v0.2, WebIDE, and Tkinter
by adafruit on Sun Jan 27, 2013 10:41 pm
the WebIDE is not intended for use with anything except for 'command line' python & our tutorials, so anything else is not supported and should be assumed to not work. we dont have any plans to make tkinter work - our priority is better command-line python support at this time, only
