Occidentalis - Shutdown??
by scampa123 on Thu Feb 07, 2013 1:43 pm
When I try to click the shutdown button in Occidentalis, the dialog pops up and I select shutdown...for a brief moment a login box appears but before I can put in a password the box disappears and the OS doesn't shutdown...
So then I select logout...This logs me out of the main OS, but on the next OS screen I click shutdown and again it won't do it...
Any ideas how I can fix this?
Thanks in advance!
Re: Occidentalis - Shutdown??
by markofzero on Sat Feb 09, 2013 1:08 pm
I shutdown using ssh with a command like this:
sudo shutdown -h now
or, to restart:
sudo shutdown -r now
I hope this helps.
by tldr on Sat Feb 09, 2013 1:57 pm
you can run the console program, (LXTerminal), and use "sudo shutdown -h 0" from there.
or typing ctl-alt-f1 will get you out of the gui to a console login. log in as root and use "shutdown -h 0" or as pi or whatever user account you have set up and use "sudo shutdown -h 0".
i'm not sure about the pi but, generally, on linux you'll have 6 such logins available, using alt-fwhatever to switch between them. alt-f7 will return you to the gui.
"If I had known it was harmless, I would have killed it myself." - Phillip K. Dick, A Scanner Darkly
