Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
16X2 LCD
16X2 LCD
by Smoothtalker on Fri Feb 15, 2013 11:44 am
Hey all,
So I just received my LCD screen, made all of the solder connections, nothing (to my knowledge) has been "crossed" while soldering the boards. However, I can only see a very faint image on the screen, and it is 8 "boxes" showing. I adjusted the contrast adjuster, and it is still showing very lightly. there is no active backlight, and when i attempt to run i2cdetect, it comes back showing the screen on 20x (which i think is a good thing). I attempt to run the test script from the install guide, and get an error back stating that it cannot connect/see the i2c device.
Any help would be greatly appreciated. Thanks!
Smoothtalker
Re: 16X2 LCD
by adafruit_support_bill on Fri Feb 15, 2013 11:54 am
Post photos of the front & back of the board and we'll check your assembly.
Re: 16X2 LCD
by Smoothtalker on Fri Feb 15, 2013 2:18 pm
http://imgur.com/Pc7LA7D
http://imgur.com/u1EzHOg
I checked again, and it def seems as though it is all connected correctly. Let me know what you think, thanks a bunch!
Smoothtalker
Re: 16X2 LCD
by adafruit_support_bill on Fri Feb 15, 2013 3:28 pm
The solder looks very good from what I can see. Can you post one showing the rest of the front (including switches & chip).
Re: 16X2 LCD
by Smoothtalker on Fri Feb 15, 2013 4:02 pm
http://imgur.com/4vW2nmI
Thanks for the help!
Smoothtalker
Re: 16X2 LCD
by adafruit_support_bill on Fri Feb 15, 2013 4:14 pm
Everything looks good.
Which I2C bus is the device detected on, 0 or 1? Does the example code use the same bus?
Rev1 of the Pi's used a different I2C bus than Rev2, so the example code may need to be tweaked to match.
Re: 16X2 LCD
by Smoothtalker on Fri Feb 15, 2013 5:45 pm
It is detected on 1. Would you be able to advise me on the code needed to change the output?
Smoothtalker
Re: 16X2 LCD
by adafruit_support_bill on Sat Feb 16, 2013 7:26 am
It is descrinbed in the tutorial here: http://learn.adafruit.com/adafruit-16x2 ... y-pi/usage
If you have a rev 2 (512MB) Pi, or if you're not getting anything displaying, it might be due to the I2C bus number change in the Pi hardware. Edit Adafruit_CharLCD.py using a command like "nano Adafruit_CharLCD.py" and change the line
lcd = Adafruit_CharLCDPlate(busnum = 0)
to
lcd = Adafruit_CharLCDPlate(busnum = 1)
