Adafruit_DHT no longer works
by jheo on Wed Feb 27, 2013 3:15 am
I bought a DHT sensor with rpi a few weeks ago and have been using it without problem so far. But today it stopped working. When I run Adafruit_DHT, it just hangs. I tried with other GPIOs, but it hangs. What should I do to find whether the sensor is defective?
jheo
Re: Adafruit_DHT no longer works
by adafruit_support_bill on Wed Feb 27, 2013 7:22 am
Is this on a breadboard? Re-seat all your connections and make sure they are secure.
by jheo on Wed Feb 27, 2013 9:43 pm
I confirmed it's well connected in several ways. I've checked with strace. In the Adafruit_DHT.c, the following part is hanging.
// wait for pin to drop?
while (bcm2835_gpio_lev(pin) == 1) {
usleep(1);
Any insight?
jheo
by adafruit_support_rick on Thu Feb 28, 2013 7:14 am
Use a multimeter to double-check for continuity between the DHT pin and the cobbler gpio pin. If that rings out, then you've probably got a bad DHT. Email support@adafruit.com with a link to this thread and ask for a replacement.
by jheo on Thu Feb 28, 2013 9:52 am
I'll check the sensor this evening again, and will contact the support.
Could you recommend a stable temperature sensor for RPi? I am measuring room temperature every 5 minutes. I found many people have trouble with DHT22. Maybe I would need to consider using a better sensor.
jheo
by adafruit_support_rick on Thu Feb 28, 2013 11:33 am
Try a digital sensor, like the DS18B20:
We have a tutorial for using it with the Pi.
