Cant get a value from mcp3008 please help.
by IslandMedic on Thu Feb 28, 2013 3:44 pm
I have been struggling trying to get this simple circuit to work. When you look at the logic analyzer output you will see the Dout line has nothing. I have the input channel for the ADC set to 2.73 volts. the code out put is all zeros. I just don't know what I am doing wrong. One question I have is, do I have to cross over din and dout. Meaning do I wire din -> SPIMISO or should it go to din -> SPIMOSI. Any thoughts or ideas would be very much appreciated.
thanks
Brad
Wiring:
MCP3008
Pin 16,15 -> rpi 3.3v
Pin 14,9 -> RPi Gnd
Pin 10 CS -> rpi 25
Pin 11 din -> rpi 24
Pin 12 dout -> rpi 23
Pin 13 clk -> rpi 22
Logic Analyzer:
Channel 0 -> mcp3008 pin 11 Din
Channel 1 -> mcp3008 pin 12 Dout
Channel 2 -> mcp3008 pin 10 CS
Channel 3 -> mcp3008 pin 13 CLK
Test code:
#!/usr/bin/env python
import time
import os
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
DEBUG = 1
# read SPI data from MCP3008 chip, 8 possible adc's (0 thru 7)
def readadc(adcnum, clockpin, mosipin, misopin, cspin):
        if ((adcnum > 7) or (adcnum < 0)):
                return -1
        GPIO.output(cspin, True)
        GPIO.output(clockpin, False)  # start clock low
        GPIO.output(cspin, False)     # bring CS low
        commandout = adcnum
        commandout |= 0x18  # start bit + single-ended bit
        commandout <<= 3    # we only need to send 5 bits here
        for i in range(5):
                if (commandout & 0x80):
                        GPIO.output(mosipin, True)
                else:
                        GPIO.output(mosipin, False)
                commandout <<= 1
                GPIO.output(clockpin, True)
        adcout = 0
        # read in one empty bit, one null bit and 10 ADC bits
        for i in range(12):
                adcout <<= 1
                if (GPIO.input(misopin)):
                        adcout |= 0x1
        adcout >>= 1       # first bit is 'null' so drop it
        return adcout
# change these as desired - they're the pins connected from the
# SPI port on the ADC to the Cobbler
SPICLK = 22
SPIMISO = 23
SPIMOSI = 24
SPICS = 25
# set up the SPI interface pins
GPIO.setup(SPIMOSI, GPIO.OUT)
GPIO.setup(SPIMISO, GPIO.IN)
GPIO.setup(SPICLK, GPIO.OUT)
GPIO.setup(SPICS, GPIO.OUT)
print "| #0 \t #1 \t #2 \t #3 \t #4 \t #5 \t #6 \t #7\t|"
print "-----------------------------------------------------------------"
while True:
        print "|",
        for adcnum in range(8):
                ret = readadc(adcnum, SPICLK, SPIMOSI, SPIMISO, SPICS)
                print ret,"\t",
        print "|"
IslandMedic
Re: Cant get a value from mcp3008 please help.
by IslandMedic on Thu Feb 28, 2013 3:47 pm
I should also mention that I am using the Adafruit Prototyping Pi Plate Kit for Raspberry Pi to make my connections. I also have one of the original RPI's
thanks
Brad
IslandMedic
by mwilson on Fri Mar 01, 2013 1:31 pm
Random idea: could you zoom in on the clock signal and make sure that a pulse lasts at least 125nsec, as required in the MCP3008 datasheet? One often thinks that bit-banging a clock in Python will guarantee suitably long pulse lengths, but RPis are fast. If the MCP3008 didn't even notice it had been clocked ...
mwilson
by IslandMedic on Fri Mar 01, 2013 6:22 pm
Thanks I hadn't considered that idea. I will play with the timing and see if that helps.
Brad
IslandMedic
