Pi Box piece too thick
by nmalinoski on Thu Feb 28, 2013 10:04 pm
I just received my RPi starter kit, and began by assembling the Pi Box, but I noticed that one of the horizontal plates (Top/Bottom) is apparently too thick to fit into the slots in the sides. If I place both top/bottom pieces side-by-side, one is noticeably thicker than the other.
I have a file on hand, and theoretically I could file the plastic so it could fit, but I've no experience with modifying acrylic plastic, so I don't know if that's actually a good idea. Obviously I wouldn't be opposed to receiving a new part.
So, what's the recommended solution to this?
nmalinoski
Re: Pi Box piece too thick
by tldr on Thu Feb 28, 2013 10:12 pm
acrylic likes to crack or shatter. it also looks really bad when scratched. and its thickness varies a great deal within a sheet, but it usually tends to run thinner than spec. i wouldn't try to fix it 'til you've been promised a replacement if the operation goes south.
"If I had known it was harmless, I would have killed it myself." - Phillip K. Dick, A Scanner Darkly
tldr
by pburgess on Thu Feb 28, 2013 10:50 pm
Hi there. Very sorry about that...please email support@adafruit.com and include your order number and a link to this post, and we'll issue a replacement.
Occasionally a sheet of acrylic comes from the factory just a little thicker than normal. The case design has enough wiggle room to handle some variation, but this must've been a particularly thick piece.
pburgess
by nmalinoski on Fri Mar 01, 2013 12:22 am
Email sent; thank you, pburgess.
nmalinoski
