Ultimate GPS + Raspi
by dronshaw on Thu Feb 28, 2013 11:42 pm
So I've run into a snag on getting data from the ultimate GPS. Right now I'm running the latest wheezy on my pi. I'm able to cgps -s fine and see the real-time data. Unfortunately, I'm having problems implementing the code they recommend:
""Now that you're GPS is up and running, and gpsd is playing nice with it, it's time to do something with the data!
The easiest way to get started is using the WebIDE and a bit of python code to access gpsd.
Create a new file in the WebIDE, and then add and run the following code:
Copy Code
import gps
# Listen on port 2947 (gpsd) of localhost
session = gps.gps("localhost", "2947")
session.stream(gps.WATCH_ENABLE | gps.WATCH_NEWSTYLE)
while True:
try:
report = session.next()
# Wait for a 'TPV' report and display the current time
# To see all report data, uncomment the line below
# print report
if report['class'] == 'TPV':
if hasattr(report, 'time'):
print report.time
except KeyError:
pass
except KeyboardInterrupt:
quit()
except StopIteration:
session = None
print "GPSD has terminated"
Since I don't have WebIDE, I create a gps.py file in /home/pi. I paste the code and then try "python gps.py" and get
File "gps.py", line 1, in <module>
import gps
File "/home/pi/gps.py", line 4, in <module>
TypeError: 'module' object is not callable
I'm VERY new to the pi/python/programming, so I hope I'm not making a stupid silly mistake, but I believe this is how you would implement this without WebIDE.
dronshaw
