Webide start stop script lost
by jumpzero on Wed Mar 20, 2013 4:07 pm
I have manage to brake my 1 day old webide.
The script /etc/init.d/adafruit-webide.sh is not anymore a valid script!
I don't know how it has happen but look the content:
root@raspberrypi:/home/pi# head /etc/init.d/adafruit-webide.sh
Default: true
Description: Do you want system-wide readable home directories?
Description-ar.utf-8: هل ترغب بجعل الأدلة المنزلية مقروءة للجميع؟
Description-be.utf-8: Ці хочаце вы, каб хатнія каталогі былі чытэльныя з усёй сістэмы?
Description-ca.utf-8: Voleu que els directoris personals siguen llegibles per tothom?
Description-cs.utf-8: Chcete domovské adresáře čitelné pro všechny uživatele v systému?
Description-da.utf-8: Ønsker du globalt læsbare hjemmemapper?
Description-de.utf-8: Wünschen Sie systemweit lesbare Home-Verzeichnisse?
Description-es.utf-8: ¿Desea que los directorios personales de los usuarios sean legibles?
Of course I cannot start Webide
Where can I find this script?
If I have more things broken can I totally re-install Occidentalis + WebIde if I save/restore this folder = ~/.ssh
root@raspberrypi:/home/pi# la /home/webide/.ssh/
total 24
drwx------ 2 webide webide 4096 Mar 18 15:29 .
drwxr-xr-x 3 webide webide 4096 Mar 18 15:33 ..
-rw-r--r-- 1 webide webide 147 Mar 18 15:29 config
-rw------- 1 webide webide 1679 Mar 18 15:29 id_rsa_bitbucket
-rw-r--r-- 1 webide webide 400 Mar 18 15:29 id_rsa_bitbucket.pub
-rw-r--r-- 1 webide webide 1326 Mar 18 15:49 known_hosts
I will keep my bitbucket account as well? Or can I delete this as well and I can retrieve my bitbucket account with the password I entered when creating the account?
Jmp0
jumpzero
Re: Webide start stop script lost
by adafruit_support_mike on Wed Mar 20, 2013 8:48 pm
You can get a fresh copy from github: https://github.com/adafruit/Adafruit-We ... er/scripts
by jumpzero on Fri Mar 29, 2013 11:47 pm
it helps me, however I had no success, to have my WebIde running again, my SD card was corrupted!
I have zeroed it, re-install Occidentalis, apt-get update; apt-get upgrade (around 270 packages ...) and
curl https://raw.github.com/adafruit/Adafrui ... install.sh | sudo sh
Ok WebIDE running again :-)
now I have re-install the whole /home/webide/ that I had backed up before zeroed the SD.
I have all the needed bucket full of bits:
root@raspberrypi:/# ls -la /home/webide/.ssh/
total 24
drwx------ 2 webide webide 4096 Mar 18 09:29 .
drwxr-xr-x 3 webide webide 4096 Mar 18 09:33 ..
-rw-r--r-- 1 webide webide 147 Mar 18 09:29 config
-rw------- 1 webide webide 1679 Mar 18 09:29 id_rsa_bitbucket
-rw-r--r-- 1 webide webide 400 Mar 18 09:29 id_rsa_bitbucket.pub
-rw-r--r-- 1 webide webide 1326 Mar 18 09:49 known_hosts
But when connecting from my browser to Webide I still go automatically to http://raspberrypi.local/setup
the screen ask me to create my BucketBit account... How get out of that and go to the true WebIDE
(If I go to Bitbucket web site I'm connected to my account)
Do I have to create new keys?
Jmp0
jumpzero
by jumpzero on Fri Mar 29, 2013 11:56 pm
Hi!
Sorry I found solution myself
From Bitbucket site I have edited Raspberry Pi webIde in integrated applications and get back my keys copy paste in WebIDE and it,s ok
Let's now fill up this bucket with some bits
Jmp0
jumpzero
