access point with 2 wifi usb
by G0ku5 on Tue Sep 17, 2013 2:28 pm
hello,
I need a help, to the creation of my wifi access point
I want to create an access point where with one usb wifi I connect to a wifi network and then use with other usb wifi access point
instead of being a regular access point, which uses a port other eth and wlan, I want to use wlan 2
is possible to do this?
if so would appreciate some help because I am newbie
thank you
G0ku5
Re: access point with 2 wifi usb
by adafruit_support_mike on Tue Sep 17, 2013 4:27 pm
I don't know if it's possible, but you can try.
Follow the instructions in this tutorial: http://learn.adafruit.com/setting-up-a- ... cess-point , using wlan0 as the access point and wlan1 as the network wlan0 connects to.
by G0ku5 on Tue Sep 17, 2013 4:58 pm
before I want to thank for the reply and the help
but I wanted to ask, how to proceed the setting, /etc/network/interfaces for this situation?
greetings
G0ku5
by adafruit_support_mike on Thu Sep 19, 2013 3:08 pm
You'd need to set up the wlan0 interface so it accepts an address from the wireless network that will provide your internet connection:
iface wlan0 inet dhcp
    wpa-ssid "ssid"
    wpa-psk "password"
or if you want to use a static IP address:
iface wlan0 inet static
    address 192.168.0.2
    netmask 255.255.255.0
    gateway 192.168.0.1
Then you'd configure wlan1 according to the instructions in the tutorial.
by G0ku5 on Sat Sep 21, 2013 4:55 am
is already running the access point with 2 usb wifi
so I have one more question, how do I connect wifi1 to a network without password?
    wpa-ssid "ssid"
thank you
G0ku5
by G0ku5 on Sat Sep 21, 2013 11:15 am
I wanted Connecting to open network,
and I'm using:
auto wlan1
allow-hotplug wlan1
iface wlan1 inet dhcp
wireless-essid NETWORK_NAME
but I can not access the internet, what am I doing wrong?
G0ku5
by adafruit_support_mike on Sat Sep 21, 2013 8:48 pm
I generally set up access to open networks in /etc/wpa_supplicant/wpa_supplicant.conf, but IIRC you can turn off the requirement for a password using this in /etc/network/interfaces using this line:
   wpa-key-mgmt NONE
by G0ku5 on Sat Oct 19, 2013 7:41 am
Hello, I think my problem is because I have repeaters, so I have 2 mac adress
I found this:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=wheel
ap_scan=1
network={
        bssid=00:50:17:31:1a:11
        ssid="YourSSID"
        psk="your-secret-key"
        scan_ssid=1
        proto=WPA2
        key_mgmt=WPA-PSK
        group=CCMP TKIP
        pairwise=CCMP TKIP
        priority=5
but do not know how I am newbie to configure my case, can you help me please
G0ku5
by G0ku5 on Sun Oct 20, 2013 5:23 pm
problem solved
thank you very much friend
regards :D
G0ku5
by adafruit_support_mike on Mon Oct 21, 2013 1:01 am
Glad to hear you got it working. Happy hacking!
