Raspberery Pi Internet Radio
Re: Raspberery Pi Internet Radio
by donde on Sun Oct 06, 2013 6:38 pm
So, the solution was
No, I used the same original Rev 2 RPi. But, I carefully re- installed all the software necessary for the project, even re-formating the SD card. I think the pops might have come from installing git the first time. I didn't see that it was already installed if I downloaded Occidentalis, which I did. But, i could have corrupted something else by getting frustrated not seeing the LCD light up. Might have re-installed this or that in the wrong order. So, really the wrong bus was the trouble. The info was there, but guess i lost focus, for documentation was confusing. Maybe, the docs could be written 2 ways, one for Rev 1 and one for Rev 2, and not mentioning anything about the other revision you're not using.
Rev1 does not work for me involving WiFi. It could be my adapter, for it draws about 210 ma, an older Belkin, but works fine with Rev 2.
donde
by kb4jhu on Sun Oct 13, 2013 1:29 am
I have completed the kit and all is working.
On power off (pressing the left button), the 30 second note is displayed on the LED screen, the sound is turned down, however the RPI never shuts down. I looked a the python code and looks like the shutdown command is not working. Can someone tell me how to fix so it shuts down correctly?
Great project. Enjoyed it so far and works great! :D
V/R
-Michael
kb4jhu
by adafruit_support_rick on Sun Oct 13, 2013 8:27 am
Did you make the following change to the PiPhy.py code, as mentioned in the tutorial?
HALT_ON_EXIT = True
by kb4jhu on Mon Oct 14, 2013 10:00 pm
Adafruit Support - Rick - Yes verified I have the code in place:
# Constants:
RGB_LCD = False # Set to 'True' if using color backlit LCD
HALT_ON_EXIT = True # Set to 'True' to shut down system when exiting
MAX_FPS = 6 if RGB_LCD else 4 # Limit screen refresh rate for legibility
VOL_MIN = -30
VOL_MAX = 5
VOL_DEFAULT = 0
HOLD_TIME = 3.0 # Time (seconds) to hold select button for shut down
PICKLEFILE = '/home/pi/.config/pianobar/state.p'
I am running Raspbian Wheezy.
The shut down error I am getting is:
PiPhi.pi line 378 in <module>
shutdown ()
File "PiPhi.py" , line 111, in shutdown
subprocess.call("sync")
NameError: global name 'subprocess' not defined
Can you tell what I need to update to fix this error for proper shut down?
Thanks again for a super product. Enjoyed adafruit for offering this kit.
V/R
-Michael
kb4jhu
by adafruit_support_rick on Tue Oct 15, 2013 5:40 am
Try executing PiPhy.py as superuser (i.e., with "sudo")
by donde on Fri Oct 18, 2013 1:59 pm
I sure like my Raspberry Pi WiFi Radio. Just for fun I measured the power the device consumes with a Harbor Freight Power Meter. While playing wireless music I see 120 volts AC at 0.04 amps, and 3 watts. I'm using the Adafruit 5 volt, 1 amp PS. I guess running the little project 24/7 would not break the bank!
I want to thank Adafruit for sharing the coding for Pi and the LCD Pi Plate. I highly reccommend this project, but you should dedicate a Pi and LCD to the Radio if you want to keep it going.
donde
donde
by adafruit_support_rick on Fri Oct 18, 2013 4:20 pm
Thanks for posting! :D
by kb4jhu on Thu Oct 24, 2013 10:53 pm
Got mine working as well and shutting down correctly. Updated the rc.local with SUDO and working great.
This is a outstanding project for anyone. Easy to build, easy to get working and then hours of enjoyment! I will look for more projects like this one!
ADAFRUIT thanks for offering this kit. I have really enjoyed building and now using WiFi audio with my RPI!
- Michael KB4JHU
kb4jhu
by donde on Thu Oct 24, 2013 11:11 pm
What did you do in rc.local? Mine shuts down, but doesn't kill power like a desktop would.
Don
donde
