"write_i2c_block_data" not working: 16-Channel 12-bit PWM Dr
by Immobilizer on Wed Oct 09, 2013 6:03 pm
Hi Everybody,
Has anyone had luck with I2C block reading/writing commands with this device (http://www.adafruit.com/products/815)? Here's what happened when I executed the following commands:
>>> from smbus import SMBus
>>> bus = SMBus(1)
>>> bus.read_i2c_block_data(0x40, 0, 10)
[17, 17, 17, 17, 17, 17, 17, 17, 17, 17]
>>> bus.read_byte_data(0x40, 0)
17
>>> bus.read_byte_data(0x40, 1)
4
>>> bus.read_i2c_block_data(0x40, 1, 10)
[4, 4, 4, 4, 4, 4, 4, 4, 4, 4]
>>> bus.write_i2c_block_data(0x40, 6, [5,4,3,2,1,10,9,8,7,6])
>>> bus.read_i2c_block_data(0x40, 6, 10)
[6, 6, 6, 6, 6, 6, 6, 6, 6, 6]
>>> bus.read_i2c_block_data(0x40, 5, 12)
[224, 224, 224, 224, 224, 224, 224, 224, 224, 224, 224, 224]
>>> bus.read_i2c_block_data(0x40, 7, 12)
[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
>>> bus.read_i2c_block_data(0x40, 6, 12)
[6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6]
>>> bus.read_i2c_block_data(0x40, 8, 12)
The "read_i2c_block_data" method appears to be reading the first byte, then filling the rest of the list with that byte.
The "write_i2c_block_data" method appears to write the last byte in the list to the starting register, but will not write any more bytes.
What am I doing wrong? I'd rather not have to initiate a new I2C command for every byte with something like
bus.write_byte_data
Thanks for your help!
Immobilizer
Re: "write_i2c_block_data" not working: 16-Channel 12-bit PW
by adafruit_support_mike on Thu Oct 10, 2013 2:19 am
Take a look at page 32 of the PCA9685 datasheet: http://www.adafruit.com/datasheets/PCA9685.pdf
When you talk to the PCA9685, you start by setting the MODE1 and MODE2 bytes. Those tell the chip what to do. Then you trigger a restart event and send any extra data. To read/write all the registers in the chip, you need to set the 'autoincrement' bit in the MODE2 register.
The sequence is a bit more complicated than a simple continued read.
