DHT22 RASBERRY PI @ REBOOT
by ECHO_MIS on Wed Oct 16, 2013 11:16 am
I have been working on a room temperature and humidity logger for an equipment room. I am using the DHT22 connected to the Rasberry PI.
I have implemented the code from Adafruit website and it works great from a shell command.
The problem I am encountering is that I would like to start the python script at boot up. I have not been able to find a successful way to start the python script at boot up. Since my Rasberry Pi will be in a remote area I would like the python script to start up every time at boot up.
I have used crontab and have created a script file which points to the python script, with no luck.
I have been able to execute other python scripts at boot up with out any problems, is their a trick to it since the python script is calling a C code.
Any suggestions would be greatly appreciated.
Best regards,
Edgar
ECHO_MIS
Re: DHT22 RASBERRY PI @ REBOOT
by franklin97355 on Wed Oct 16, 2013 4:56 pm
Edgar, this would be more suited in the General Projects or Raspberry pi accessories sections as it has nothing to do with Arduinos.
franklin97355
by adafruit_support_mike on Wed Oct 16, 2013 5:09 pm
Moved to the RasPi forum, and could you please post the code you're using, both the crontab entry and the script it calls.
by ECHO_MIS on Wed Oct 16, 2013 5:28 pm
Sure will sorry about that, new to this forum.
ECHO_MIS
by adafruit_support_mike on Thu Oct 17, 2013 2:01 am
Enh.. it's not like we're going to take you out back and beat up your Arduino. ;-)
What code are you trying to launch? If you've gotten other scripts to launch with the same method, you're probably running into an error that causes the script to fail rather than running.
by waltr on Thu Oct 17, 2013 11:32 am
Googling "linux start python progrm on boot" found a number of answers including the Raspberry Pi Org forum.
There are many ways to start a program on boot in linux. One of the methods discussed should work to way you needed it to.
waltr
