Adafruit 16 channel bldc control
by Stefan Fruhwirth on Wed Oct 23, 2013 1:13 pm
I have a problem with the adafruit 16 channel board to control a brushless bldc 720 controller.
The bldc motor run only in full power mode.
What is wrong, Have anyone an idee?
But the standard servo with 180° work fine
with regards
Stefan
Stefan Fruhwirth
Re: Adafruit 16 channel bldc control
by adafruit_support_bill on Wed Oct 23, 2013 1:17 pm
Do you have a link to a spec for the controller?
by Stefan Fruhwirth on Wed Oct 23, 2013 1:26 pm
this is the link
http://learn.adafruit.com/adafruit-16-c ... spberry-pi
#define SERVOMIN 160 // servo travel limit (160/4095 * 20ms = 0.8ms pulse)
#define SERVONEUTRAL 300 //servo neutral position (300/4095 * 20ms = 1.5ms pulse)
#define SERVOMAX 440 // servo travel limit (440/4095 * 20ms = 2.2ms pulse)
this are my defines
Stefan Fruhwirth
by adafruit_support_bill on Wed Oct 23, 2013 1:31 pm
That is our PWM controller. not a BLDC controller. You mentioned a "brushless bldc 720 controller". Where is the spec sheet for that?
by Stefan Fruhwirth on Wed Oct 23, 2013 1:40 pm
Stefan Fruhwirth
by adafruit_support_bill on Wed Oct 23, 2013 1:44 pm
Can you post a photo of how you have it connected? - And the code you are using.
by Stefan Fruhwirth on Wed Oct 23, 2013 1:51 pm
the connection is correct
Controll the Carson Servo
//Servo Carson, funktioniert schon
servoControl.set_PWM(fd, 0, 0, SERVOMIN); //ganz links 500
sleep(1);
servoControl.set_PWM(fd, 0, 0, SERVONEUTRAL); //neutral 1300
sleep(1);
servoControl.set_PWM(fd, 0, 0, SERVOMAX); //ganz rechts 2100
sleep(1);
sleep(1);
I am using the library "wiringPi" in combination with a raspberry pi
but the bl controller 720 doesnt work correct with the 16 channel board
void Servo::set_PWM(int fd, int channel, uint16_t on, uint16_t off){
//"Sets a single PWM channel"
wiringPiI2CWriteReg8(fd, LED0_ON_L+4*channel, on & 0xFF);
wiringPiI2CWriteReg8(fd, LED0_ON_H+4*channel, on >>8);
wiringPiI2CWriteReg8(fd, LED0_OFF_L+4*channel, off & 0xFF);
wiringPiI2CWriteReg8(fd, LED0_OFF_H+4*channel, off >>8);
if I set the pwm by the bldc controler to 1350, the motor go in full power
set_PWM(fd, 15, 0, 1350); but under this, the motor isnt running, and i dont can control the power
have you an idee?
connect
Stefan Fruhwirth
cron
