LCD Plate on Arch Linux
by matstone99 on Wed Oct 23, 2013 7:51 pm
I've successfully been able to get my LCD Plate working on Raspbian so I know it is working, but despite reading every forum post, article, and tutorial I could find, I haven't been able to get it to work on Arch Linux ARM.
I've enabled i2c_dev and i2c_bcm2708 on boot as confirmed by the output of lsmod:
[root@cloudmonitor15 device]# lsmod
Module                  Size  Used by
arc4                    1707  2
rt2800usb              16847  0
rt2800lib              68820  1 rt2800usb
rt2x00usb              11477  1 rt2800usb
rt2x00lib              44200  3 rt2x00usb,rt2800lib,rt2800usb
mac80211              463046  3 rt2x00lib,rt2x00usb,rt2800lib
cfg80211              425157  2 mac80211,rt2x00lib
evdev                  10085  0
crc_ccitt               1553  1 rt2800lib
leds_gpio               2075  0
led_class               3861  2 leds_gpio,rt2x00lib
spi_bcm2708             4771  0
i2c_bcm2708             3949  0
i2c_dev                 5573  0
ipv6                  309456  0
But when I run i2cdetect -y 1 (I have rev. 2 RPi) I get no devices showing up on the addresses:
[root@cloudmonitor15 device]# i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
How do I get the i2c to work correctly on Arch so I can use the LCD Plate?
matstone99
Re: LCD Plate on Arch Linux
by adafruit_support_mike on Wed Oct 23, 2013 11:57 pm
Just to check, try:
i2cdetect -y 0
Also make sure your permissions are right by running both versions with `sudo`. There are so many dialects of Linux out there that sometimes you have to poke at things for a while to translate commands from one to the next.
by matstone99 on Thu Oct 24, 2013 3:06 am
Here is the output of running the commands both with and without the sudo command (I'm logged in on the root account):
[root@cloudmonitor15 ~]# i2cdetect -y 0
[root@cloudmonitor15 ~]# sudo i2cdetect -y 0
[root@cloudmonitor15 ~]# i2cdetect -y 1
[root@cloudmonitor15 ~]# sudo i2cdetect -y 1
matstone99
by adafruit_support_mike on Thu Oct 24, 2013 3:04 pm
I did some digging WRT Arch Linux, and found a couple of pages that show sample `lsmod` output from systems that eventually worked. The only difference I saw was a line like so:
i2c_core               15344  3 i2c_dev,rtc_pcf8563,lm85
Your output above doesn't show that module in the list.
Check to see if the module is even there:
ls /sys/module/i2c*
and try to enable it if it does exist:
modprobe i2c_core
