Chronodot Installation
I have added a RTC to my Raspi using Chronodot and PiPlate. After I installed the board and ran i2cdetect it recognized the device displaying 0x68. Subsequently, I accidently pulled out the usb wireless devicewith the Pi still on. The Pi booted immediately with no problems, but when I ran i2cdetect again the device did not show up (just UU). What is the likelihood that I fried the chronodot, or worse something related to i2c on the Pi? Is there any way of testing before I replace? (or give up!)
- adafruit_support_rick
Re: Chronodot Installation
Are you certain you didn't simply jostle the I2C wires loose? It's hard to imagine that toasting the Chronodot.
You might try resetting the chronodot: with the power off, remove and reinstall the backup battery.
Ive tested the connections from i2c to chronodot and nothing seems to be amiss. I've also reset the chronodot but the result is the same. Is there anyway to test the chronodot?
The only way to test it would be with another microcontroller, like an Arduino or another Pi. Have you got anything like that?
No. Is there anyway, at least, to tell if the problem is not the Pi?
If you have another i2c device, you could connect that and see if it works. That would verify that the Pi i2c bus was still functional.
I purchased and installed a RasClock and there was no problem. I think this implies that pulling out the wifi dongle fried the ChromoDot. Since it worked before I pulled the dongle out, I'm assuming the wiring is fine.
Thanks for the suggestions
- donde
My project is similiar, except I'm using the less costly 1307 chip. I saw a 68 in the beginning also, but later it became a UU, and the my RTC was way off the right time. I sent in a question to this forum, and got back this from Mike of Adafruit. I was able to clear the time trouble doing updates and correcting a RTC option. The UU is still there.
So, I think your Chronodot is OK. Hope this helps.The 'UU' means that a kernel module is using that address, so the general probe is skipping over the address to avoid messing with the existing connection.
That's a good thing. It means the kernel module which you enabled is probably talking to the RTC. Try rebooting the RasPi and see if it syncs to the RTC.
