Hey.
Is it possible to use the SI1145 uv sensor at Raspberry pi b+ ?
https://learn.adafruit.com/adafruit-si1 ... ble-sensor
I have some confusion with the pins.
- If it is possible; how to get started?
-Christian
SI1145 UV sensor
- adafruit_support_rick
Re: SI1145 UV sensor
The Si1145 is an I2C device, so it's easy to connect to the Pi. We have a python I2C driver available, but we don't have any code specifically for the Si1145. You'll have to write that yourself.
All you need to do is connect GND to GND, 3.3v to Vin, SDA to SDA, and SCL to SCL.
- primexandy
I have just got the Pi working with the SI1145 in C / C++. If you are interest in the code I can share it with you.
- egutting
I'll be writing a driver on it for python later this week once I get the sensor. (Supposed to be in on Wednesday)
- egutting
You can find the driver in this post:
http://forums.adafruit.com/viewtopic.php?f=50&t=59913
- ChristianIsobar
Thank you very much, i will look into it asap! (Thank you!)
Is it possible to use the UV without soldering the wires to the pins?
-Christian
-Christian
No. You must use solder.ChristianIsobar wrote: Is it possible to use the UV without soldering the wires to the pins?
- ChristianIsobar
I've soldered it.
I can't get your script working @egutting getting:
I guess i have to install the Adafruit_GPIO, but got some troubles installing that aswell
I'm working through SSH (putty)
And is it possible to check if the UV sensor is connected correctly ?
-Christian
./examples/simpletest.py
File "./examples/simpletest.py", line 29, in <module>
import SI1145.SI1145 as SI1145
File "/usr/local/lib/python2.7/dist-packages/SI1145-1.0.0-py2.7.egg/SI1145/SI1145.py", line 28, in <module>
import Adafruit_GPIO.I2C as I2C
ImportError: No module named Adafruit_GPIO.I2C
git clone https://github.com/adafruit/Adafruit_Python_GPIO.git
Cloning into 'Adafruit_Python_GPIO'...
error: Couldn't resolve host 'github.com' while accessing https://github.com/adafruit/Adafruit_Python_GPIO.git/info/refs
fatal: HTTP request failed
-Christian
- egutting
The Adafruit GPIO library is set as a dependency and it should have installed when you installed the SI1145 library. When you did "git clone library address", did you go to the folder and type "sudo python setup.py install"? Let me know if you did this and it's not working. The Adafruit library you need is located here:
Also, to see if the sensor is connected correctly, you can run: sudo i2cdetect -y 1
If the address of the sensor (0x60) shows up, then it should be connected correctly.
- ChristianIsobar
Yes but got an error;
I've tried to install from that yes.
- Thank you for your help so far, i hope it will going to work.
Where should i write do the i2cdetect command?
- I mean in which folder? (does it matter)
(im new to the phyton world)
-Christian
Installed /usr/local/lib/python2.7/dist-packages/SI1145-1.0.0-py2.7.egg
Processing dependencies for SI1145==1.0.0
Searching for Adafruit-GPIO>=0.2.0
Best match: Adafruit-GPIO 0.2.0
Downloading https://github.com/adafruit/Adafruit_Python_GPIO/tarball/master#egg=Adafruit-GPIO-0.2.0
error: Download error for https://github.com/adafruit/Adafruit_Python_GPIO/tarball/master: [Errno -2] Name or service not known
-Christian
- egutting
You can run i2cdetect in any folder.
I may need to fix that dependency link. I'll look into that when I get home this evening. You should be able to install the GPIO library in the same way you installed the SI1145 one though to get it working.
You can follow this tutorial to set up GPIO
https://learn.adafruit.com/adafruits-ra ... gpio-setup
- egutting
I just tried to install on a fresh copy of Raspbian and it worked. Not sure what may be the issue with yours not downloading the Adafruit GPIO library.
- ChristianIsobar
Again, thank you for your help and time.
It seems like i have some connection issues, tried a simple ping.
- With no succes.
So i will first fix that problem, and then i will come back with an answer if its working or not :).
- Trying the new inputs you've replied with.
- Christian
- With no succes.
- Christian
- ChristianIsobar
Hey again.
It seemed that there was troubles with the connection of the device, which is solved now (yay!)
I've installed everthing on new, and its working perfectly.
Thank you so much for your help!
- Christian
- Christian
