Help with shutting down lcd and raspberry pi from CharLCD
matboy16
Post by matboy16 »
Here is my code for a raspberry pi email alert using a raspberry pi RGB Char LCD Plate. Could someone help me to write some code to get out of the while loop, shut down the pi and the LCD with a push of a button on the Char LCD Plate?
#!/usr/bin/env python
import time
import feedparser
import math
import Adafruit_CharLCD as LCD
USERNAME = ""
PASSWORD = ""
LOOP=
NEWMAIL_OFFSET = 0
MAIL_CHECK_FREQ  = 30
lcd = LCD.Adafruit_CharLCDPlate()
while True:
        newmails = int(feedparser.parse("https://" + USERNAME + ":" + PASSWORD + "@mail.google.com/gmail/feed/atom")["feed"]["fullcount"])
   if newmails > 0:
               # print "You have ", newmails, "new emails!"
                lcd.set_color(1.0, 0.0, 0.0)
                lcd.clear()
                lcd.message("You have Mail!")
                time.sleep(0.25)
        if newmails <= 0:
                #print "You Have no new mail!"
                lcd.set_color(0.0, 1.0, 0.0)
                lcd.clear()
                lcd.message("No new mail!")
                time.sleep(0.25)
        time.sleep(MAIL_CHECK_FREQ)
adafruit_support_mike
Re: Help with shutting down lcd and raspberry pi from CharLC
Change the control condition for the while loop from True to a variable named keepLooping which starts as True and gets set False when you find a condition that makes you want to stop the loop:
import random
keepLooping = True
while keepLooping:
	n = random.random()
	print n
	if ( n > 0.95 ):
		keepLooping = False
matboy16
Post by matboy16 »
Is their a piece of code that I can write that will stop the program, even in the middle of time.sleep function? The button press only work if the code is not inside of the time.sleep fucton. Could I make a interrupt that will shut down the entire program with a push of a button on the lcd_plate.
adafruit_support_rick
Just use an inner loop in place of your sleep. Have the loop check the button. Have the loop sleep for something like 50ms, then check the button. Loop 600 times and exit, and you'll have done the same thing as sleeping for 30 seconds.
matboy16
Post by matboy16 »
Thanks that helps a lot, this is why I love buying things from adafruit. The costomer service is awesome. Thanks for the help, you deserve a big thank you!!!!
You're welcome!
