Hi
I just got my PiTFT (PID 1601)
I went through the install proceedure
after entering the:
sudo modprobe spi-bcm2708
sudo modprobe fbtft_device name=adafruitts rotate=90
export FRAMEBUFFER=/dev/fb1
startx
The console screen goes from white to black and then comes back on as the directions say but
I get an error code window:
Error
GDBus, Error:org.freedesktop,PolicyKit1.Error,Failed:An
authentication agent already exists for the given subject
and the PiTFT is a not-too-bright solid gray
the Pi is running on a new version of NOOBS from Adafruit
eta it is a B+ Pi
touch screen problem
Re: touch screen problem
The error means you're running another desktop for the same user on another display.
PolicyKit is a feature of LXDE (the desktop manager) that restricts access to things like the GPIO pins. You can shut it off by pulling up the Preferences -> Desktop Settings pane and unchecking "Authentication Agent". Restart the RasPi after that and the error should go away.
Yes I found that on another forum and unchecking it in preferences works
but the TFT still does not work properly
I now get a screen on the tft but it is now saying near the end of the boot up:
27.041632] fbtft_device: missing module parameter: 'name'
This shows up after entering:
"Module Auto-loading
We'll now make the modules auto-load. Lets edit the /etc/modules list with
sudo nano /etc/modules
add two lines
spi-bcm2708
fbtft_device <---- is this a typo in the detailed installation -- there is no 'name' parameter
Then Control-X Y [return] to save <-- and this is confusing and needs to be rewritten (IMO)
I am going to try the easy install
does adafruit plan to offer a NOOBS micro sd chip with the tft files loaded ? I would buy one
add two lines
spi-bcm2708
So I did the easy install (and it really is easy thanks)
but this is what is now happening
I reboot, at some point in the reboot the tft displays the start up code but then
the gray screen after the HMDI comes up with the desktop
there is a non flashing 'cursor' line on the display but that's all
did I miss something ? I tried rebooting it with the HDMI unplugged -- still no display after the kernal code
I checked the cmdline.txt
" At the end of the line, find the text that says rootwait and right after that, enter in:
fbcon=map:10 fbcon=font:VGA8x8 then save the file."
and it is OK
and it is OK
I went back and ran this
startx
and it works
I must have messed something up trying the detailed install
however it seems I have to run the above code after a reboot in order for the display to work
startx
and it works
You can add those lines to the end of /etc/rc.local to have the system run them as part of the boot process.
- RobotPi
I have the same problem on a B+.
I installed the software following the instructions for the kernel (the existing image takes too long to discard).
I have tried the above fix but that causes the HDMI monitor to black out (bar a brief small display of rainbow like box in top right of screen) and the Touchscreen to remain grey small pixels. There is no other display on the touchscreen but it is responding to styluses on the configuration tests (but not displaying any image)
Even in the mid-gray pixel mode it does respond to the mouse
Any suggestions?
Any suggestions?
- RobotPi
So no response on this issue.
So I reflashed a micro-sd card with the recommended image (https://learn.adafruit.com/adafruit-pit ... sy-install ).
This causes the B+ to halt in the pi startup script at the point where the B+ is configuring the touchscreen device!
This is starting to sound like a B+ bug to me
- RobotPi
We tried another Touchscreen with success - this is using our existing Rasbian image with the kernel extension for the TS.
We can swap between HDMI and touchscreen and use the two buttons for power and Pi reboot
Good news except
- the MicroSD image linked above still hangs.
Good news except
