gpio serial transmit distance
- timwjkl
How far from the R pi can i have my arduino that is connected by GPIO and level shifter? Inches , feet , yards? I am only receiving data from arduino by design
- adafruit_support_rick
Re: gpio serial transmit distance
That actually depends on the baud rate. At a few yards, you should be OK with lower rates. The level shifter will act as a repeater, so you can extend your range by putting it in the middle of the run.
- timwjkl
I am using 9600 for the baud rate and and planing on using cat 5e cable unless something else will work better ? trying for 100~ feet
- timwjkl
well So far i can transmit to at least 25 foot that is the longest piece of cat 5 I had at my desk. works fine also can program from my comp easy too with it hooked to a ftdi friend..
Anyone figured how to reprogram using a raspberry pi without being able to push the reset button?
I used the same cable to run serial gpio with the arduino too now to find my box of cable and check out the 100 foot :-)
All you need is a low pulse on the reset pin.
If you have a free line in your CAT5, you could wire another switch to the RESET pin through the cable. You could also drive the wire from one of the RasPi's outputs.
- timwjkl
I used the directions from the alamode http://baldwisdom.com/simplified-setup- ... pberry-pi/ and used RX,TX and gpio 18 on the pi and the arduino Rx Tx and reset with level shifter757 and a https://www.adafruit.com/products/72
With the extra cap at C6 it auto reset and programed the arduino without a reset button push.
I have been at this for a week and now i got out the 4X glasses and lo and behold i had the reset pins offset at the level shifter ( face palm)
Been there. ;-)
I've miswired enough connections that I've learned to do two things: test each connection as it's made, and use a schematic with a checklist any time I inspect a circuit. It's *way* too easy to see what you think should be there instead of what's really there.
