I purchased a 7" display back in late Jan of this year and received it in Feb. I have used this item two times as a small troubleshooting display since then. Last week I hooked up this display to view a HDMI output and it would not work I then tried it on VGA which it had worked two times before. It also did not work. It appears that it can not sink on the signal.
I think 6 month and two uses is rather poor reliability for any product.
It was purchased on invoice 421756. Part number HDMI 4 PI - 7" Display 1280 x 800 IPS.
Please let me know anything else that can be done and if this part is still covered under warranty.
Failure of HDMI 4 PI - 7" Display PID 1033
- adafruit_support_rick
Re: Failure of HDMI 4 PI - 7" Display PID 1033
Unfortunately, out replacement period is 30 days.
What exactly are the symptoms? Do any lights come on? Do you see the blue screen when it's searching for a signal?
Or is it just dark and inert?
- rmfinsmt
The blue light is on. The screen comes up with different verticals lines and changes if the menu button is pressed. It looks like it cannot sync. I have reduced the resolution down to 800 by 600 but that does not make a difference. I have input both html and VGA inputs cycling power each time changing. I can take a photo of the screens if that would help.
You might try a different power supply for the screen.
