I'm using a PiTFT with my Raspberry Pi and mostly it is working fine - I've set it to auto boot to the desktop when it is turned on.
However, I'd now like to 'disable' the TFT and use the HDMI instead but I can't get it to work.
I've tried calling FRAMEBUFFER=/dev/fb0 startx & as per the FAQ, and moving the .conf file, but without success.
I've also tried disabling the call to fbtft_device in /etc/modules but then I can't start the desktop at all...In this case it starts up correctly and keeps outputting to the HDMI whilst in the command line but a call to startx then generates the error.
Can anyone help please? I just want an easy way to choose whether the PiTFT gets used or not.
Thanks,
Martin
PiTFT - Start X on HDMI instead of PiTFT
Re: PiTFT - Start X on HDMI instead of PiTFT
The "FRAMEBUFFER=/dev/fb0 startx &" line should do it..
How did you set things up so it would boot to the PiTFT? Did you call that version of `startx` from /etc/rc.local, a crontab, or some other source?
Thank you for the help. Because I've changed the default user from pi I don't use raspi-config to boot to the desktop but I did have the /usr/share/X11/xorg.conf.d/99-pitft.conf in place.
That meant that everytime I called 'startx' from the command line (or from within crontab), or 'FRAMEBUFFER=/dev/fb0 startx' it would always use the PiTFT. Now I've removed this file it works perfectly and I can choose which framebuffer is used for X.
Glad to hear it's working for you.
