Followed the install instructions, everything appeared to install correctly.
When I try to run:
sudo python freqshow.py
The program exits with the error message:
Kernel driver is active, or device is claimed by second instance of librtlsdr. In the first case, please either detach or blacklist the kernel module (dev_usb_rtl28xxu), or enable automatic detaching at compile time.
usb_claim_interface error 6...
Any suggestions on how can I fix the problem?
Thanks in advance,
Mitch W4OA
Freq Show: Raspberry Pi RTL-SDR Scanner problem
- mitchsfm
- tdicola
Re: Freq Show: Raspberry Pi RTL-SDR Scanner problem
Thanks for checking out the project! Interesting, the issue you see is that the linux kernel has built in support for the digital TV tuner that RTL-SDR uses, and it conflicts with the RTL-SDR driver. When the RTL-SDR code is compiled there's a special flag passed in (-DDETACH_KERNEL_DRIVER=ON) which should enable it to automatically detach the kernel's digital TV tuner driver that conflicts. However if it's not working for you for some reason let's try manually disabling the driver.
Edit the file /etc/modprobe.d/raspi-blacklist.conf and add this line anywhere in it:
Save, then reboot the Pi and check if you can run the software now. Let me know if that helps, thanks!
blacklist dev_usb_rtl28xxu
- mitchsfm
Hey... Just got a chance to check out your suggestion. Modified the /etc/modprobe.d/raspi-blacklist.conf file by adding the suggested line, blacklist dev_usb_rtl28xxu ...
Got the exact same error message. Any other suggestion?
Mitch
(sempra)
Mitch
(sempra)
- mitchsfm
- tdicola
Thanks for grabbing the details. Hrm, that is really odd that it's still complaining about the driver conflicting. Just to check is there any other instance of freq show running, or any other RTL SDR tools?
Also can you run this command to list all the loaded kernel modules and grab the output to copy here--let's see if something else might be related and conflicting:
lsmod
- mitchsfm
- mitchsfm
To answer your questions, no other programs running, just a clean boot and run freqshow. No RTL SDR tools running.
- tdicola
Thanks for grabbing the output of lsmod. It looks like for some reason the digital TV tuner driver is still loaded, even though it should be in the blacklist configuration. Try running these commands to manually unload the tuner (until the next reboot):
Lets give that a shot to see if it can manually unload the conflicting drivers.
sudo modprobe -r dvb_usb_rt128xxu
sudo modprobe -r dvb_usb_v2
sudo modprobe -r dvb_core
- mitchsfm
Yes! That did it!!!
Now to find a speaker and play with the software!
Many thanks for a GREAT project,
Mitch W4OA
(sempra)
Mitch W4OA
(sempra)
- tdicola
Oh nice, glad you got it working. On reboot you might need to run those commands again to disable the kernel module. You might try updating the blacklist file to list all of those modules that the modprobe command runs, similar to the earlier blacklist file update. Hopefully that will keep them from loading and causing issues. Thanks for checking out the project!
- fmohammed
I am not sure this is the same or similar issue. I have followed the setup instructions and I even added the running drivers to the blacklist items in the /etc/modprobe.d/raspi-blacklist.conf file. However I have an error,
pi@RaspScan ~/FreqShow $ sudo python freqshow.py
Detached kernel driver
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
rtlsdr_demod_write_reg failed with -1
rtlsdr_demod_read_reg failed with -1
r82xx_write: i2c wr failed=-1 reg=06 len=1
rtlsdr_demod_read_reg failed with -4
rtlsdr_write_reg failed with -4
Reattaching kernel driver failed!
File "freqshow.py", line 103, in <module>
fscontroller.current().render(screen)
File "/home/pi/FreqShow/views.py", line 364, in render
self.render_spectrogram(screen.subsurface(spect_rect))
File "/home/pi/FreqShow/views.py", line 461, in render_spectrogram
freqs = self.model.get_data()
File "/home/pi/FreqShow/model.py", line 159, in get_data
samples = self.sdr.read_samples(freqshow.SDR_SAMPLE_SIZE)[0:self.width+2]
File "/usr/local/lib/python2.7/dist-packages/rtlsdr/rtlsdr.py", line 328, in read_samples
raw_data = self.read_bytes(num_bytes)
File "/usr/local/lib/python2.7/dist-packages/rtlsdr/rtlsdr.py", line 312, in read_bytes
% (result, num_bytes))
IOError: Error code -1 when reading 2048 bytes
and I see the drivers in the lsmod.
lsmod:
Module Size Used by
joydev 9745 0
stmpe_ts 4560 0
snd_bcm2835 20924 0
snd_pcm 92398 1 snd_bcm2835
snd_seq 60741 0
snd_seq_device 7194 1 snd_seq
snd_timer 22618 2 snd_pcm,snd_seq
snd 66956 5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
evdev 10819 3
ir_lirc_codec 4952 0
ir_xmp_decoder 2909 0
lirc_dev 10992 1 ir_lirc_codec
ir_mce_kbd_decoder 4290 0
ir_sharp_decoder 2201 0
ir_sanyo_decoder 2425 0
ir_sony_decoder 2206 0
ir_jvc_decoder 2179 0
ir_rc6_decoder 2931 0
ir_nec_decoder 2619 0
ir_rc5_decoder 2251 0
fb_hx8357d 4453 1
r820t 17225 1
dvb_usb_rtl28xxu 17041 0
i2c_bcm2708 6136 0
rtl2830 8144 1 dvb_usb_rtl28xxu
rtl2832 9966 2 dvb_usb_rtl28xxu
spi_bcm2708 8865 0
i2c_mux 2460 1 rtl2832
dvb_usb_v2 15747 1 dvb_usb_rtl28xxu
dvb_core 99727 3 rtl2830,rtl2832,dvb_usb_v2
rc_core 23405 14 ir_sharp_decoder,ir_xmp_decoder,lirc_dev,ir_lirc_codec,dvb_usb_rtl28xxu,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,ir_mce_kbd_decoder,ir_jvc_decoder,dvb_usb_v2,ir_rc6_decoder,ir_sanyo_decoder
uio_pdrv_genirq 3653 0
uio 9837 1 uio_pdrv_genirq
Any recommendations would be appreciated.
Regards.
lsmod:
Module Size Used by
joydev 9745 0
stmpe_ts 4560 0
snd_bcm2835 20924 0
snd_seq 60741 0
evdev 10819 3
fb_hx8357d 4453 1
r820t 17225 1
i2c_bcm2708 6136 0
spi_bcm2708 8865 0
Regards.
- tdicola
Hrm that's odd, all of the error messages make me think the RTL-SDR driver code is having trouble communicating with the tuner dongle. One thing to check is to make sure you're powering the Raspberry Pi with a good quality 1-2 amp power supply. The tuner will draw a decent amount of power so if the supply can't keep up with the demand the voltage might drop a bit and cause problems when talking to the tuner.
Also do any of the other RTL-SDR tools work? Like rtl_tune, rtl_test, etc--can see more details on them here: http://sdr.osmocom.org/trac/wiki/rtl-sdr#Usage
- fmohammed
That was it. I bought a new PSU and everthing works. I guess the old PSU just wasn't good anymore.
Regards.
Regards.
- tdicola
Oh good to hear it was just a power issue, thanks for the followup and good luck with the project!
