I recently purchased a Pi B+, I already have 2 of the Pi B and they still work great. However the B+ Just stopped working and doesn’t respond at all, just a faint flicker of the LED but no video, no boot, nothing. I have checked the board and no fuses are blown and all the components look intact.
I believe it may be faulty, but I am open to suggestions?
I have tried
- Multiple power sources
- Multiple SD Cards
- Different O/S's
- Wifi and Ethernet connections
- HDMI connection
No power, no video, just a weird flicker from the LED's like they aren't getting enough power.
Faulty Pi B+
Re: Faulty Pi B+
Do you get a faint green glow on the activity LED (green) next to the power LED (red)?
- Parksie
Re: Faulty Pi B+
Just a faint glow from both LED's, I have attached some images.
- Parksie
Re: Faulty Pi B+
How do I go about getting a replacement? I emailed your company and they told me to post here, so I have done so. However, the response is a little slow here, and to be honest having a returns process in a public forum is not ideal from a customer perspective.
Re: Faulty Pi B+
Let's make sure the supply power is good:
Check the voltage between pad PP3 (GND) and PP1 (VCC) near the polyfuse F3 on the bottom of the board (near the micro-USB jack).
- Parksie
Re: Faulty Pi B+
adafruit_support_mike wrote:Let's make sure the supply power is good:
4.92v
Also, I just noticed serious heat coming from the smaller chip near the usb ports.
Re: Faulty Pi B+
That's the USB/Ethernet hub. It's normal for those to run hot.
The voltage on the supply rails looks good, so there seems to be a problem somewhere further into the board.
Send a note to [email protected] with a link to this thread and the folks there will get you a new B+.
