I have this Raspberry Pi camera project (putting a pi + camera inside of a Polaroid 95 bellows camera). At the moment, I'm using revision 1.0 of the Rasberry Pi that I got during the initial Pi ordering and the 2.8" PiTFT screen. However, I'm finding the PiTFT screen to be on the slow side, so in today's 12% off sale, I ordered the HDMI 5" display w/touchscreen (https://www.adafruit.com/products/2109) and the 4400ma battery (https://www.adafruit.com/product/1565).
Now, the battery only has one USB port. Do I need to get/make a USB Y-cable to split the power between the two devices, or can I connect the 5v/ground from the Pi, and will it have enough power to power the monitor (i.e. if I have a 1A supply coming into the micro-USB power plug, can I attach a 500mA device directly to the gpio pins without blowing something up)?
In addition, assuming some day I rev up to a B+ model with 4 USB ports, would I be able to power the 5" display through the USB ports (i.e. if I have a 1A power supply to the micro-USB port, can I draw 500mA from the USB port, or do I need to use a GPIO port)?
I've burned out microprocessors and external camera flashes, so I figured I would ask before trying it, and releasing the magic smoke.
Powering a Raspberry Pi and 5" HDMI/VGA/NTSC + touchscreen +
- michaelmeissner
- adafruit_support_rick
Re: Powering a Raspberry Pi and 5" HDMI/VGA/NTSC + touchscre
According to this page, the max current draw on the 5V GPIO pins is USB - 700mA for the Pi (model B) itself. So, with a 1A supply, you can get 300mA from the 5V GPIO
(the B+ uses slightly less power - 650mA).
In any case, you can't get 500mA out of the USB ports. It's limited to 120mA on the Model B. I couldn't find a spec on the B+ USB current, but I don't expect it to be much different.
- michaelmeissner
Thanks Rick. I figured as much, so I need to make a Y cable to power both the pi and screen off of a battery with a single USB plug. I was hoping however, that it would be easy to do otherwise.
You could use the 5V GPIO pins as well. However, the product page for that battery says it produces up to 1A, which isn't enough for a Pi and the display together.
- michaelmeissner
Bummer, it looks like I need to rethink the power options. At least I can use the battery for other projects.
I've measured the Pi + camera + PiTFT + RTC needing about 750mA, which would give me about 4-5 hours of runtime on the battery. The problem is the 2.8" PiTFT is on the slow side, and I hoped to have more resolution and higher speed by going to HDMI.
Ah, well I was tempted by the sale to jump in without doing extensive research.
Still worth giving it a try - maybe the battery will put out a little extra.
- michaelmeissner
Yep, always worth a shot. And besides I do have other projects that I could use it on that aren't as power hungry. I did want the other battery that is 10000mA capacity, 2A power and 2 USB plugs (https://www.adafruit.com/products/1566), but that was out of stock.
I do have two battery/chargers from Radio Shack that claim to deliver 5v/2A (or 9v/1.5A or 12v/1.3A), so I probably will use those initially, but they are a little bulky.
