PiTFT 3.5" touch screen not working
palon7
Post by palon7 »
Hi.
I was downloaded image from https://learn.adafruit.com/adafruit-pit ... sy-install, and install to raspberry pi.
Display is working, but touch screen is not working.
I type "sudo evtest /dev/input/touchscreen", but return:
evtest: No such file or directory
Part of dmesg:
[   10.812653] bcm2708_i2c_init_pinmode(0,0)
[   10.818543] bcm2708_i2c_init_pinmode(0,1)
[   10.827326] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100000)
[   10.839591] bcm2708_i2c_init_pinmode(1,2)
[   10.845235] bcm2708_i2c_init_pinmode(1,3)
[   10.854290] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
[   10.994648] i2c /dev entries driver
[   11.266016] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[   11.286573] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[   11.467925] fbtft_device:  SPI devices registered:
[   11.474396] fbtft_device:      spidev spi0.0 500kHz 8 bits mode=0x00
[   11.487920] fbtft_device:      spidev spi0.1 500kHz 8 bits mode=0x00
[   11.496066] fbtft_device:  'fb' Platform devices registered:
[   11.503274] fbtft_device:      bcm2708_fb id=-1 pdata? no
[   11.510392] fbtft_device:  I2C devices registered:
[   11.516760] fbtft_device:       i2c-0  addr 48908  IRQ 0
[   11.523531] fbtft_device:       i2c-1  addr 48908  IRQ 1
[   11.530294] fbtft_device:      pcm5122 1-004d  addr 77  IRQ 0
[   11.537520] fbtft_device:      wm8804 1-003b  addr 59  IRQ 0
[   11.544592] fbtft_device:      pcm5122 1-004c  addr 76  IRQ 0
[   11.631088] fbtft_device: Deleting spi0.1 (spi0.1)
[   11.640545] stmpe-spi spi0.1: unknown chip id: 0x0
[   11.653973] stmpe-spi: probe of spi0.1 failed with error -22
[   11.675547] fbtft_device: Deleting spi0.0 (spi0.0)
[   11.682339] fbtft_device:  GPIOS used by 'adafruitrt35':
[   11.695545] fbtft_device:    'dc' = GPIO25
[   11.701083] fbtft_device:  SPI devices registered:
[   11.719483] fbtft_device:      stmpe610 spi0.1 500kHz 8 bits mode=0x00
[   11.735576] fbtft_device:      fb_hx8357d spi0.0 32000kHz 8 bits mode=0x00
[   13.182856] graphics fb1: fb_hx8357d frame buffer, 480x320, 300 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
I tried reinsert flex cable(http://forums.adafruit.com/viewtopic.php?f=50&t=66668), but not changed.
thanks,
Palon
adafruit2
Re: PiTFT 3.5" touch screen not working
Post by adafruit2 »
Try removing power, wait a few minutes, then restart the Pi, then post up the output of dmesg again - we'll take a look :)
palon7
Post by palon7 »
OK. I try this and show:
[   11.042594] bcm2708_i2c_init_pinmode(0,0)
[   11.048461] bcm2708_i2c_init_pinmode(0,1)
[   11.057177] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100000)
[   11.069445] bcm2708_i2c_init_pinmode(1,2)
[   11.075096] bcm2708_i2c_init_pinmode(1,3)
[   11.084231] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
[   11.224018] i2c /dev entries driver
[   11.501336] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[   11.518564] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[   11.702593] fbtft_device:  SPI devices registered:
[   11.716906] fbtft_device:      spidev spi0.0 500kHz 8 bits mode=0x00
[   11.724945] fbtft_device:      spidev spi0.1 500kHz 8 bits mode=0x00
[   11.733058] fbtft_device:  'fb' Platform devices registered:
[   11.740394] fbtft_device:      bcm2708_fb id=-1 pdata? no
[   11.747453] fbtft_device:  I2C devices registered:
[   11.753740] fbtft_device:       i2c-0  addr 48908  IRQ 0
[   11.760598] fbtft_device:       i2c-1  addr 48908  IRQ 1
[   11.767447] fbtft_device:      pcm5122 1-004d  addr 77  IRQ 0
[   11.774644] fbtft_device:      wm8804 1-003b  addr 59  IRQ 0
[   11.781775] fbtft_device:      pcm5122 1-004c  addr 76  IRQ 0
[   11.865395] fbtft_device: Deleting spi0.1 (spi0.1)
[   11.877188] stmpe-spi spi0.1: unknown chip id: 0x0
[   11.883480] stmpe-spi: probe of spi0.1 failed with error -22
[   11.905692] fbtft_device: Deleting spi0.0 (spi0.0)
[   11.917316] fbtft_device:  GPIOS used by 'adafruitrt35':
[   11.924085] fbtft_device:    'dc' = GPIO25
[   11.945634] fbtft_device:  SPI devices registered:
[   11.951890] fbtft_device:      stmpe610 spi0.1 500kHz 8 bits mode=0x00
[   11.963075] fbtft_device:      fb_hx8357d spi0.0 32000kHz 8 bits mode=0x00
[   13.433994] graphics fb1: fb_hx8357d frame buffer, 480x320, 300 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
adafruit2
Post by adafruit2 »
hmm, can you take a photo of the back of the PiTFT 3.5"? just wanna see if anything clearly is amiss :)
palon7
Post by palon7 »
OK.
adafruit2
Post by adafruit2 »
ok lets get you another one - email support@adafruit with a link to this thread! :)
