PITFT-Assembled 480x320 3.5 not working
k_pierce
Post by k_pierce »
HI I ordered Tuesday 03 feb invoice no 697754
I am having trouble with my pitft, it only displays a white screen. I have tried all the trouble shooting in the forums. I have used a ribbon cable and tried plugging in the other header pins but still get white screen. I have also hooked it up to a monitor and press ALT-F2 and i get the desktop monitor with login prompt.
adafruit_support_rick
Re: PITFT-Assembled 480x320 3.5 not working
Post by adafruit_support_rick »
Can you post the output of
sudo dmesg
k_pierce wrote:I have used a ribbon cable and tried plugging in the other header pins but still get white screen.
You mean you have tried it plugged directly into the Pi, right?
Are you using the easy-install image from here?
https://learn.adafruit.com/adafruit-pit ... o-go-image
k_pierce
Post by k_pierce »
yes i have plugged directly into the Pi. I will try that image and get back with you
k_pierce
Post by k_pierce »
Okay i have tried that image and plugged the pitft back in and still get white screen. I then tried it with a monitor and i get the boot screen.
Can you post the output of sudo dmesg please?
k_pierce
Post by k_pierce »
Linux raspberrypi 3.12.26+ #7 PREEMPT Wed Sep 17 14:25:24 EDT 2014 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Feb 11 01:08:16 2015 from lee-pc.att.net
pi@raspberrypi ~ $ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.12.26+ (ladyada@ladyada-VirtualBox) (gcc version 4.4.7 (Ubuntu/Linaro 4.4.7-1ubuntu2) ) #7 PREEMPT Wed Sep 17 14:25:24 EDT 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr =00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruc tion cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 8 MiB at 1b800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c0670468, node_mem_map c072100 0
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 b cm2708_fb.fbheight=416 bcm2708.boardrev=0xe bcm2708.serial=0x4a3deaad smsc95xx.m acaddr=B8:27:EB:3D:EA:AD sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base =0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115 200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:VGA8x8
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 439204K/458752K available (4815K kernel code, 243K rwdata , 1352K rodata, 146K init, 701K bss, 19548K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc060dee4 (6168 kB)
[ 0.000000] .init : 0xc060e000 - 0xc0632a44 ( 147 kB)
[ 0.000000] .data : 0xc0634000 - 0xc0670d60 ( 244 kB)
[ 0.000000] .bss : 0xc0670d6c - 0xc0720228 ( 702 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:394
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4 294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001259] Calibrating delay loop (skipped), value calculated using timer fr equency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001324] pid_max: default: 32768 minimum: 301
[ 0.001780] Mount-cache hash table entries: 512
[ 0.002584] Initializing cgroup subsys memory
[ 0.002697] Initializing cgroup subsys devices
[ 0.002737] Initializing cgroup subsys freezer
[ 0.002771] Initializing cgroup subsys blkio
[ 0.002909] CPU: Testing write buffer coherency: ok
[ 0.003405] Setting up static identity map for 0xc04965e0 - 0xc049663c
[ 0.005346] devtmpfs: initialized
[ 0.021515] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.023152] NET: Registered protocol family 16
[ 0.028547] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.029268] cpuidle: using governor ladder
[ 0.029322] cpuidle: using governor menu
[ 0.029773] bcm2708.uart_clock = 0
[ 0.031850] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.031914] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.031952] mailbox: Broadcom VideoCore Mailbox driver
[ 0.032056] bcm2708_vcio: mailbox at f200b880
[ 0.032170] bcm_power: Broadcom power driver
[ 0.032210] bcm_power_open() -> 0
[ 0.032237] bcm_power_request(0, 8)
[ 0.532957] bcm_mailbox_read -> 00000080, 0
[ 0.533002] bcm_power_request -> 0
[ 0.533205] Serial: AMBA PL011 UART driver
[ 0.533394] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.891010] console [ttyAMA0] enabled
[ 0.917698] bio: create slab <bio-0> at 0
[ 0.923437] SCSI subsystem initialized
[ 0.927467] usbcore: registered new interface driver usbfs
[ 0.933194] usbcore: registered new interface driver hub
[ 0.938781] usbcore: registered new device driver usb
[ 0.945433] Switched to clocksource stc
[ 0.949704] FS-Cache: Loaded
[ 0.952874] CacheFiles: Loaded
[ 0.969128] NET: Registered protocol family 2
[ 0.974613] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.982046] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.988648] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.995102] TCP: reno registered
[ 0.998407] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.004281] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.011002] NET: Registered protocol family 1
[ 1.016012] RPC: Registered named UNIX socket transport module.
[ 1.021975] RPC: Registered udp transport module.
[ 1.026799] RPC: Registered tcp transport module.
[ 1.031525] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.038975] bcm2708_dma: DMA manager at f2007000
[ 1.043740] bcm2708_gpio: bcm2708_gpio_probe c0641e70
[ 1.049299] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000 000(512 MiB)
[ 1.058886] audit: initializing netlink socket (disabled)
[ 1.064401] type=2000 audit(0.910:1): initialized
[ 1.239861] VFS: Disk quotas dquot_6.5.2
[ 1.244137] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.253102] FS-Cache: Netfs 'nfs' registered for caching
[ 1.260057] NFS: Registering the id_resolver key type
[ 1.265245] Key type id_resolver registered
[ 1.269575] Key type id_legacy registered
[ 1.274326] msgmni has been set to 873
[ 1.280172] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 52)
[ 1.288058] io scheduler noop registered
[ 1.292019] io scheduler deadline registered (default)
[ 1.297647] io scheduler cfq registered
[ 1.302747] BCM2708FB: allocated DMA memory 5bc00000
[ 1.307950] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.317742] Console: switching to colour frame buffer device 82x52
[ 1.326979] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driv er
[ 1.334754] uart-pl011 dev:f1: no DMA platform data
[ 1.340530] vc-cma: Videocore CMA driver
[ 1.344530] vc-cma: vc_cma_base = 0x00000000
[ 1.349409] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.354876] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.369889] brd: module loaded
[ 1.378348] loop: module loaded
[ 1.381835] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[ 1.389863] Loading iSCSI transport class v2.0-870.
[ 1.396105] usbcore: registered new interface driver smsc95xx
[ 1.402204] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.609765] Core Release: 2.80a
[ 1.614386] Setting default values for core params
[ 1.620695] Finished setting default values for core params
[ 1.827789] Using Buffer DMA mode
[ 1.832545] Periodic Transfer Interrupt Enhancement - disabled
[ 1.839821] Multiprocessor Interrupt Enhancement - disabled
[ 1.846859] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.852643] Dedicated Tx FIFOs mode
[ 1.858020] WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xdbc 14000 dma = 0x5bc14000 len=9024
[ 1.870850] FIQ FSM acceleration enabled for :
[ 1.870850] Non-periodic Split Transactions
[ 1.870850] Periodic Split Transactions
[ 1.870850] High-Speed Isochronous Endpoints
[ 1.893155] dwc_otg: Microframe scheduler enabled
[ 1.893256] WARN::hcd_init:473: FIQ at 0xc0364444
[ 1.899458] WARN::hcd_init:474: FIQ ASM at 0xc0364858 length 36
[ 1.906920] WARN::hcd_init:500: MPHI regs_base at 0xdc806000
[ 1.913994] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.920336] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.929125] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.936111] Init: Port Power? op_state=1
[ 1.941443] Init: Power Port (0)
[ 1.946398] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.954610] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.963293] usb usb1: Product: DWC OTG Controller
[ 1.969431] usb usb1: Manufacturer: Linux 3.12.26+ dwc_otg_hcd
[ 1.976718] usb usb1: SerialNumber: bcm2708_usb
[ 1.983520] hub 1-0:1.0: USB hub found
[ 1.988899] hub 1-0:1.0: 1 port detected
[ 1.994736] dwc_otg: FIQ enabled
[ 1.994759] dwc_otg: NAK holdoff enabled
[ 1.994770] dwc_otg: FIQ split-transaction FSM enabled
[ 1.994791] Module dwc_common_port init
[ 1.995245] usbcore: registered new interface driver usb-storage
[ 2.003197] mousedev: PS/2 mouse device common for all mice
[ 2.011035] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 2.018442] bcm2835-cpufreq: switching to governor powersave
[ 2.025581] bcm2835-cpufreq: switching to governor powersave
[ 2.032711] sdhci: Secure Digital Host Controller Interface driver
[ 2.040341] sdhci: Copyright(c) Pierre Ossman
[ 2.046218] sdhci: Enable low-latency mode
[ 2.095500] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platfor m's DMA
[ 2.106432] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.113893] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.121208] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.130965] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.145580] usbcore: registered new interface driver usbhid
[ 2.152748] usbhid: USB HID core driver
[ 2.162762] TCP: cubic registered
[ 2.169681] Initializing XFRM netlink socket
[ 2.177567] NET: Registered protocol family 17
[ 2.183726] Key type dns_resolver registered
[ 2.192952] Indeed it is in host mode hprt0 = 00021501
[ 2.204047] registered taskstats version 1
[ 2.226178] Waiting for root device /dev/mmcblk0p2...
[ 2.257672] mmc0: read SD Status register (SSR) after 2 attempts
[ 2.278609] mmc0: new high speed SDHC card at address b368
[ 2.296097] mmcblk0: mmc0:b368 NCard 3.73 GiB
[ 2.303549] mmcblk0: p1 p2
[ 2.353629] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 2.365018] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.374026] devtmpfs: mounted
[ 2.379141] Freeing unused kernel memory: 144K (c060e000 - c0632000)
[ 2.415625] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.424206] Indeed it is in host mode hprt0 = 00001101
[ 2.636060] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.644430] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.654639] hub 1-1:1.0: USB hub found
[ 2.660262] hub 1-1:1.0: 3 ports detected
[ 2.945797] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.076224] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.084770] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[ 3.113571] smsc95xx v1.0.4
[ 3.180675] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1 .1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3d:ea:ad
[ 3.901539] udevd[156]: starting version 175
[ 4.968559] Adafruit Industries' Raspberry Pi PWM driver v1.0
[ 5.978458] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 9.569903] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.064981] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.856024] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 10.876253] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 11.048439] fbtft_device: SPI devices registered:
[ 11.054979] fbtft_device: spidev spi0.0 500kHz 8 bits mode=0x00
[ 11.074246] fbtft_device: spidev spi0.1 500kHz 8 bits mode=0x00
[ 11.082474] fbtft_device: 'fb' Platform devices registered:
[ 11.089872] fbtft_device: bcm2708_fb id=-1 pdata? no
[ 11.096952] fbtft_device: I2C devices registered:
[ 11.175564] fbtft_device: Deleting spi0.1 (spi0.1)
[ 11.188770] stmpe-spi spi0.1: stmpe610 detected, chip id: 0x811
[ 11.213572] fbtft_device: Deleting spi0.0 (spi0.0)
[ 11.226103] fbtft_device: GPIOS used by 'adafruitrt35':
[ 11.233081] fbtft_device: 'dc' = GPIO25
[ 11.255618] fbtft_device: SPI devices registered:
[ 11.262032] fbtft_device: stmpe610 spi0.1 500kHz 8 bits mode=0x00
[ 11.285631] fbtft_device: fb_hx8357d spi0.0 32000kHz 8 bits mode=0x00
[ 11.378461] input: stmpe-ts as /devices/platform/bcm2708_spi.0/spi_master/spi 0/spi0.1/stmpe-ts.0/input/input0
[ 13.294521] graphics fb1: fb_hx8357d frame buffer, 480x320, 300 KiB video mem ory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 22.046229] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 23.642724] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E 1
[ 25.549132] bcm2835-cpufreq: switching to governor ondemand
[ 25.549167] bcm2835-cpufreq: switching to governor ondemand
[ 30.841278] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2 134012k SSFS
pi@raspberrypi ~ $
adafruit2
Post by adafruit2 »
OK one last thing, just check the back, the two little side nubs on the flex connector, sometimes they come loose! Make sure they are totally closed, you can use needlenose pliers to snap them closed.
If that doesn't help please email support@adafruit and ask for a replacement and a RETURN LABEL with RMA "FORPHIL" - we'd like to see what happened since this is a rare event!
