New users of the PiTFT who follow the driver install instructions at https://learn.adafruit.com/adafruit-pit ... ed-install may have noticed that those drivers replace the current Raspbian kernel with an older one, and they may decide to try and recompile the drivers. This currently doesn't work for the latest release kernel.
The cross-post:
To compile the drivers from source, follow the steps here up to (and including) "Get the kernel source":
http://elinux.org/Raspberry_Pi_Kernel_Compilation
Once you get the kernel source downloaded, you follow the instructions at the bottom of the page below. However, the Adafruit drivers are a fork of a driver called fbtft, and the instructions are for fbtft, not adafruit:
https://github.com/xobs/adafruit-rpi-fbtft
...so, here are the edited instructions for this step:
In the downloaded kernel source directory:
> cd drivers/video
> git clone https://github.com/xobs/adafruit-rpi-fbtft
Add to drivers/video/Kconfig:
source "drivers/video/adafruit-rpi-fbtft/Kconfig"
Add to drivers/video/Makefile:
obj-y += adafruit-rpi-fbtft/
Then, return to the step "Get the compiler" in the kernel source compile instructions and follow the remaining instructions.
When you get to the step
> make ARCH=arm CROSS_COMPILE=${CCPREFIX} oldconfig
You'll be asked a bunch of things on the command line. You can hit return for all *except* the questions about enabling small TFT support. Enter Y Return, and then you will have to choose the specific driver by entering M or y. If you want the drivers as part of the kernel, it is yes. If you want as a separate module, you have to press M here for "ili9340" only (at least for the 3.5" which I have. no need to compile all the other types).
If you miss it (there's a bunch to click through and it's easy to miss), you can still enable the driver in the next command, but only as kernel included, not as a module.
The next command:
make ARCH=arm CROSS_COMPILE=${CCPREFIX} menuconfig
> allows you to again select which drivers to include but as you already did it on the command line, Drivers > Graphical Drivers > Small TFT etc. should already be selected.
Then follow the remaining steps. If you use kernel 3.18.y, compilation will probably fail.
The errors issued are:
drivers/video/adafruit-rpi-fbtft/fbtft-sysfs.c:150:2: error: negative width in bit-field ‘<anonymous>’
https://github.com/notro/fbtft/commit/4 ... 30c77fd782
Another error is:
drivers/video/adafruit-rpi-fbtft/fbtft_device.c:330:5: error: unknown field ‘irq_base’ specified in initializer
