I tried to install the PiTFT Capacitive Touchscreen on my Raspberry Pi 2 this morning using the Easy Install. I also set it up to boot to the desktop using the instructions from the FAQ. I performed the update, upgrade, and rpi-update this weekend so I should be up-to-date on that side. I also reseated the ribbon cable when it first arrived since it was loose on one end.
Note: The Raspberry Pi is my first first Linux computer. I've only had it for a few weeks.
dmesg
sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.8-v7+ (root@vagrant-ubuntu-precise-32) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #2 SMP PREEMPT Mon Mar 9 14:11:05 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80834a00, node_mem_map ba093000
[ 0.000000] Normal zone: 1888 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8620->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ba060000 s12224 r8192 d20544 u40960
[ 0.000000] pcpu-alloc: s12224 r8192 d20544 u40960 alloc=10*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=592 bcm2708_fb.fbheight=448 bcm2709.boardrev=0xa01041 bcm2709.serial=0xef77462e smsc95xx.macaddr=B8:27:EB:77:46:2E bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:VGA8x8
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 940672K/966656K available (5828K kernel code, 403K rwdata, 1776K rodata, 392K init, 772K bss, 25984K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x807754b4 (7606 kB)
[ 0.000000] .init : 0x80776000 - 0x807d8000 ( 392 kB)
[ 0.000000] .data : 0x807d8000 - 0x8083cd6c ( 404 kB)
[ 0.000000] .bss : 0x8083cd6c - 0x808fde94 ( 773 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000016] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000039] Switching to timer-based delay loop, resolution 52ns
[ 0.000338] Console: colour dummy device 80x30
[ 0.001875] console [tty1] enabled
[ 0.001927] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.002009] pid_max: default: 32768 minimum: 301
[ 0.002434] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002495] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003795] Initializing cgroup subsys memory
[ 0.003885] Initializing cgroup subsys devices
[ 0.003943] Initializing cgroup subsys freezer
[ 0.003994] Initializing cgroup subsys net_cls
[ 0.004058] Initializing cgroup subsys blkio
[ 0.004172] CPU: Testing write buffer coherency: ok
[ 0.004281] ftrace: allocating 20136 entries in 60 pages
[ 0.054087] CPU0: update cpu_capacity 1024
[ 0.054166] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.054205] [bcm2709_smp_prepare_cpus] enter
[ 0.054376] Setting up static identity map for 0x540a38 - 0x540a90
[ 0.114014] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.114322] CPU1: Booted secondary processor
[ 0.114330] [bcm2709_secondary_init] enter cpu:1
[ 0.114382] CPU1: update cpu_capacity 1024
[ 0.114391] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.133992] [bcm2709_boot_secondary] cpu:2 started (0) 16
[ 0.134253] CPU2: Booted secondary processor
[ 0.134260] [bcm2709_secondary_init] enter cpu:2
[ 0.134289] CPU2: update cpu_capacity 1024
[ 0.134298] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.154055] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.154293] CPU3: Booted secondary processor
[ 0.154300] [bcm2709_secondary_init] enter cpu:3
[ 0.154333] CPU3: update cpu_capacity 1024
[ 0.154342] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.154441] Brought up 4 CPUs
[ 0.154563] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.154597] CPU: All CPU(s) started in SVC mode.
[ 0.155610] devtmpfs: initialized
[ 0.181035] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.183195] pinctrl core: initialized pinctrl subsystem
[ 0.187022] NET: Registered protocol family 16
[ 0.192708] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.213852] cpuidle: using governor ladder
[ 0.243882] cpuidle: using governor menu
[ 0.244333] bcm2709.uart_clock = 3000000
[ 0.247914] No ATAGs?
[ 0.247976] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.248031] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.248090] mailbox: Broadcom VideoCore Mailbox driver
[ 0.248230] bcm2708_vcio: mailbox at f300b880
[ 0.248594] bcm_power: Broadcom power driver
[ 0.248630] bcm_power_open() -> 0
[ 0.248655] bcm_power_request(0, 8)
[ 0.749334] bcm_mailbox_read -> 00000080, 0
[ 0.749366] bcm_power_request -> 0
[ 0.749511] Serial: AMBA PL011 UART driver
[ 0.749676] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.271825] console [ttyAMA0] enabled
[ 1.347496] SCSI subsystem initialized
[ 1.351510] usbcore: registered new interface driver usbfs
[ 1.357180] usbcore: registered new interface driver hub
[ 1.362638] usbcore: registered new device driver usb
[ 1.369670] Switched to clocksource arch_sys_counter
[ 1.405206] FS-Cache: Loaded
[ 1.408469] CacheFiles: Loaded
[ 1.424155] NET: Registered protocol family 2
[ 1.429969] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.437184] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.443875] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.450370] TCP: reno registered
[ 1.453621] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.459603] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.466350] NET: Registered protocol family 1
[ 1.471205] RPC: Registered named UNIX socket transport module.
[ 1.477148] RPC: Registered udp transport module.
[ 1.481936] RPC: Registered tcp transport module.
[ 1.486654] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.494165] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 1.502609] bcm2708_dma: DMA manager at f3007000
[ 1.507410] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.517463] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.523971] audit: initializing netlink subsys (disabled)
[ 1.529440] audit: type=2000 audit(1.299:1): initialized
[ 1.551289] VFS: Disk quotas dquot_6.5.2
[ 1.555606] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.565316] FS-Cache: Netfs 'nfs' registered for caching
[ 1.571595] NFS: Registering the id_resolver key type
[ 1.576740] Key type id_resolver registered
[ 1.581034] Key type id_legacy registered
[ 1.586174] msgmni has been set to 1853
[ 1.591703] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.599321] io scheduler noop registered
[ 1.603303] io scheduler deadline registered (default)
[ 1.608788] io scheduler cfq registered
[ 1.615294] BCM2708FB: allocated DMA memory fac00000
[ 1.620343] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.631538] Console: switching to colour frame buffer device 74x56
[ 1.642189] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.649933] uart-pl011 dev:f1: no DMA platform data
[ 1.655413] vc-cma: Videocore CMA driver
[ 1.659388] vc-cma: vc_cma_base = 0x00000000
[ 1.664180] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.669638] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.687016] brd: module loaded
[ 1.696405] loop: module loaded
[ 1.700004] vchiq: vchiq_init_state: slot_zero = 0xba800000, is_master = 0
[ 1.707745] Loading iSCSI transport class v2.0-870.
[ 1.713737] usbcore: registered new interface driver smsc95xx
[ 1.719622] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.925834] Core Release: 2.80a
[ 1.929028] Setting default values for core params
[ 1.935903] Finished setting default values for core params
[ 2.143864] Using Buffer DMA mode
[ 2.149124] Periodic Transfer Interrupt Enhancement - disabled
[ 2.156942] Multiprocessor Interrupt Enhancement - disabled
[ 2.164509] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.170887] Dedicated Tx FIFOs mode
[ 2.176689] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 2.190567] FIQ FSM acceleration enabled for :
[ 2.190567] Non-periodic Split Transactions
[ 2.190567] Periodic Split Transactions
[ 2.190567] High-Speed Isochronous Endpoints
[ 2.215036] dwc_otg: Microframe scheduler enabled
[ 2.215102] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x803e9a8c
[ 2.222951] WARN::hcd_init_fiq:413: FIQ ASM at 0x803e9de8 length 36
[ 2.231141] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb80a000
[ 2.239091] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.245943] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.256965] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.264430] Init: Port Power? op_state=1
[ 2.270289] Init: Power Port (0)
[ 2.275702] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.286316] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.297430] usb usb1: Product: DWC OTG Controller
[ 2.304137] usb usb1: Manufacturer: Linux 3.18.8-v7+ dwc_otg_hcd
[ 2.312172] usb usb1: SerialNumber: bcm2708_usb
[ 2.319702] hub 1-0:1.0: USB hub found
[ 2.325494] hub 1-0:1.0: 1 port detected
[ 2.331868] dwc_otg: FIQ enabled
[ 2.331882] dwc_otg: NAK holdoff enabled
[ 2.331893] dwc_otg: FIQ split-transaction FSM enabled
[ 2.331935] Module dwc_common_port init
[ 2.332326] usbcore: registered new interface driver usb-storage
[ 2.340659] mousedev: PS/2 mouse device common for all mice
[ 2.348900] bcm2835-cpufreq: min=600000 max=900000
[ 2.356035] sdhci: Secure Digital Host Controller Interface driver
[ 2.364228] sdhci: Copyright(c) Pierre Ossman
[ 2.370793] DMA channels allocated for the MMC driver
[ 2.409717] Load BCM2835 MMC driver
[ 2.417582] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.429349] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.439834] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.447581] usbcore: registered new interface driver usbhid
[ 2.456292] usbhid: USB HID core driver
[ 2.464598] TCP: cubic registered
[ 2.472031] Initializing XFRM netlink socket
[ 2.478377] NET: Registered protocol family 17
[ 2.488329] Key type dns_resolver registered
[ 2.495187] Registering SWP/SWPB emulation handler
[ 2.502945] registered taskstats version 1
[ 2.509265] vc-sm: Videocore shared memory driver
[ 2.515965] [vc_sm_connected_init]: start
[ 2.522620] [vc_sm_connected_init]: end - returning 0
[ 2.527524] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.529646] mmc0: new high speed SDHC card at address 59b4
[ 2.530237] mmcblk0: mmc0:59b4 00000 7.35 GiB
[ 2.532827] mmcblk0: p1 p2 < p5 p6 > p3
[ 2.561288] Indeed it is in host mode hprt0 = 00021501
[ 2.582931] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.595084] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[ 2.661369] devtmpfs: mounted
[ 2.667088] Freeing unused kernel memory: 392K (80776000 - 807d8000)
[ 2.739790] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.748482] Indeed it is in host mode hprt0 = 00001101
[ 2.950096] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.961135] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.973498] hub 1-1:1.0: USB hub found
[ 2.979481] hub 1-1:1.0: 5 ports detected
[ 3.259881] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.370100] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.381287] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.396159] smsc95xx v1.0.4
[ 3.464659] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:77:46:2e
[ 4.005981] udevd[174]: starting version 175
[ 4.409440] Driver for 1-wire Dallas network protocol.
[ 4.425421] w1-gpio onewire@0: gpio pin 4, external pullup pin -1, parasitic power 0
[ 4.441134] w1_add_master_device: set_pullup requires write_byte or touch_bit, disabling
[ 4.555322] GPIO $bb878000 = 0x24800000
[ 4.563735] GPIO $bb878004 = 0x24024
[ 4.590368] * 0xbb878000 &= ~ 0xE00000
[ 4.598280] * 0xbb878000 | 4 << 0x0015
[ 4.604700] * 0xbb878000 &= ~ 0x7000000
[ 4.610860] * 0xbb878000 | 4 << 0x0018
[ 4.616814] * 0xbb878000 &= ~ 0x38000000
[ 4.623126] * 0xbb878000 | 4 << 0x001B
[ 4.629277] * 0xbb878004 &= ~ 0x0007
[ 4.644312] * 0xbb878004 | 4 << 0x0000
[ 4.659747] * 0xbb878004 &= ~ 0x0038
[ 4.665573] * 0xbb878004 | 4 << 0x0003
[ 4.675756] GPIO $bb878000 = 0x24800000
[ 4.718391] GPIO $bb878004 = 0x24024
[ 4.754122] bcm2708_spi 3f204000.spi: DMA channel 2 at address 0xf3007200 with irq 77
[ 4.767776] bcm2708_spi 3f204000.spi: DMA channel 4 at address 0xf3007400 with irq 20
[ 4.827186] stmpe-spi spi0.1: unknown chip id: 0x0
[ 4.852660] stmpe-spi: probe of spi0.1 failed with error -22
[ 4.931090] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.949852] fbtft_of_value: buswidth = 8
[ 4.963039] fbtft_of_value: debug = 0
[ 4.969435] fbtft_of_value: rotate = 90
[ 4.975784] fbtft_of_value: fps = 20
[ 5.245486] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 5.260733] bcm2708_spi 3f204000.spi: SPI Controller at 0x3f204000 (irq 80)
[ 5.269417] bcm2708_spi 3f204000.spi: SPI Controller running in dma mode
[ 5.278149] bcm2708_i2c_init_pinmode(1,2)
[ 5.284057] bcm2708_i2c_init_pinmode(1,3)
[ 5.290612] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 6.435359] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
[ 6.729479] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 7.038257] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 7.190036] random: nonblocking pool is initialized
[ 12.133262] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 13.706295] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 16.668787] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 20.694914] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 53.870519] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
[ 113.180678] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
[ 160.541090] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered.
[ 231.801450] w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered.
[ 291.111683] w1_master_driver w1_bus_master1: Family 0 for 00.a00000000000.af is not registered.
[ 326.524612] w1_master_driver w1_bus_master1: Family 0 for 00.600000000000.65 is not registered.
[ 363.852012] w1_master_driver w1_bus_master1: Family 0 for 00.e00000000000.e9 is not registered.
[ 422.712386] w1_master_driver w1_bus_master1: Family 0 for 00.100000000000.9d is not registered.
[ 459.022470] w1_master_driver w1_bus_master1: Family 0 for 00.900000000000.11 is not registered.
[ 529.385624] w1_master_driver w1_bus_master1: Family 0 for 00.500000000000.db is not registered.
[ 577.643087] w1_master_driver w1_bus_master1: Family 0 for 00.d00000000000.57 is not registered.
[ 602.123306] w1_master_driver w1_bus_master1: Family 0 for 00.300000000000.be is not registered.
[ 648.466009] w1_master_driver w1_bus_master1: Family 0 for 00.b00000000000.32 is not registered.
[ 684.893830] w1_master_driver w1_bus_master1: Family 0 for 00.700000000000.f8 is not registered.
[ 733.154019] w1_master_driver w1_bus_master1: Family 0 for 00.f00000000000.74 is not registered.
[ 791.627133] w1_master_driver w1_bus_master1: Family 0 for 00.080000000000.c2 is not registered.
[ 840.854713] w1_master_driver w1_bus_master1: Family 0 for 00.880000000000.4e is not registered.
[ 876.204804] w1_master_driver w1_bus_master1: Family 0 for 00.480000000000.84 is not registered.
[ 923.505073] w1_master_driver w1_bus_master1: Family 0 for 00.c80000000000.08 is not registered.
[ 994.945403] w1_master_driver w1_bus_master1: Family 0 for 00.280000000000.e1 is not registered.
[ 1054.195700] w1_master_driver w1_bus_master1: Family 0 for 00.a80000000000.6d is not registered.
[ 1113.449039] w1_master_driver w1_bus_master1: Family 0 for 00.680000000000.a7 is not registered.
[ 1150.716751] w1_master_driver w1_bus_master1: Family 0 for 00.e80000000000.2b is not registered.
[ 1209.697345] w1_master_driver w1_bus_master1: Family 0 for 00.180000000000.5f is not registered.
[ 1246.067645] w1_master_driver w1_bus_master1: Family 0 for 00.980000000000.d3 is not registered.
[ 1292.350943] w1_master_driver w1_bus_master1: Family 0 for 00.580000000000.19 is not registered.
[ 1340.668874] w1_master_driver w1_bus_master1: Family 0 for 00.d80000000000.95 is not registered.
[ 1365.208995] w1_master_driver w1_bus_master1: Family 0 for 00.380000000000.7c is not registered.
[ 1411.611814] w1_master_driver w1_bus_master1: Family 0 for 00.b80000000000.f0 is not registered.
[ 1471.759761] w1_master_driver w1_bus_master1: Family 0 for 00.780000000000.3a is not registered.
[ 1520.080360] w1_master_driver w1_bus_master1: Family 0 for 00.f80000000000.b6 is not registered.
[ 1578.670632] w1_master_driver w1_bus_master1: Family 0 for 00.040000000000.61 is not registered.
[ 1627.951083] w1_master_driver w1_bus_master1: Family 0 for 00.840000000000.ed is not registered.
[ 1687.141543] w1_master_driver w1_bus_master1: Family 0 for 00.440000000000.27 is not registered.
[ 1734.501407] w1_master_driver w1_bus_master1: Family 0 for 00.c40000000000.ab is not registered.
[ 1757.841322] w1_master_driver w1_bus_master1: Family 0 for 00.240000000000.42 is not registered.
[ 1817.151728] w1_master_driver w1_bus_master1: Family 0 for 00.a40000000000.ce is not registered.
[ 1842.411582] w1_master_driver w1_bus_master1: Family 0 for 00.640000000000.04 is not registered.
[ 1889.771764] w1_master_driver w1_bus_master1: Family 0 for 00.e40000000000.88 is not registered.
