RP 2, 3.5" PiTFT - auto startx issue
sonic78
Post by sonic78 »
On a clean rasbian install (RP 2) I followed the new instructions to install the 3.5" PiTFT drivers. This all went fine. I selected the option to always display the console.
When ssh-ed into the box I can successfully start X Server by running
export FRAMEBUFFER=/dev/fb1
startx
However if I set always start GUI via raspi-config, the system boots and I see the console, then it blanks and I see a blank screen with a solid cursor in top corner. FRAMEBUFFER wasn't in my env vars before I export it so it's not over writing anything.
I tried to set FRAMEBUFFER in /etc/profile to see if it'd make a difference bit it didn't.
What am I missing? I just want the pi to always boot to the GUI.
Thanks for any help.
adafruit_support_mike
Re: RP 2, 3.5" PiTFT - auto startx issue
Try these instructions from the resistive PiTFT tutorial:
https://learn.adafruit.com/adafruit-pit ... s-on-pitft
They'll work the same for any version or kind of touchscreen.
jlayhue
Post by jlayhue »
Mike, those instructions worked great for me. The missing piece was adding the new "/usr/share/X11/xorg.conf.d/99-pitft.conf" file. Thanks!
jayanty10
Post by jayanty10 »
I seem to be facing the same problem. I followed all the instructions so that the GUI altostratus and sends output to the TFT screen including creating the file /usr/share/X11/xorg.conf.d/99-pitft.conf
Unfortunately, when I auto start X the TFT screen goes blank. If i attempt startx manually from the console or an SSH session then X starts up normally and output is redirected to the TFT.
Not sure what I should be looking at to debug.
Post the contents of your 99-pitft.conf file and we'll make sure it has all the information it needs.
