Power Boost 500 Basic is not Working/
- ThePotatoLord
I have been working on the PiGRRL project for a school course (https://learn.adafruit.com/pigrrl-raspberry-pi-gameboy). After hooking up the required parts, (except for the SNES controller circuits) I noticed that the LED light on the Power Boost 500 Basic was not working, so I could not tell if power was flowing through my Raspberry Pi. I tested all of my components (using a multimeter to see if electricity was flowing through it) , and saw that after hooking up the Power Boost 500 Basic, the multimeter no longer picked up a current. I have tried everything, and my teacher suggesting posting this on the forum to see if I could get a replacement part. Feedback is appreciated.
Re: Power Boost 500 Basic is not Working/
Post a photo of your hardware and connections and we'll see what we can find.
- ThePotatoLord
Here's a picture. Just so you know, the circuits have been soldered and unsoldered a few times while I was testing it.
- unnamed.jpg (36.03 KiB) Viewed 496 times
Let's start with the basics: what voltage do you get between the PCB connections on the PowerBoost's JST connector?
- ThePotatoLord
When I tested the battery without the power boost, it said it produced 3.7v. When I attached the power boost, it said it produced 0v, and the ED light would only turn on when it was plugged into a charger. Sorry I am taking so long to reply. My teacher said I may need a replacement, but suggested I post on the forum just to be safe.
That sounds like a problem we know.. what resistance do you get between the PowerBoost's JST connectors when the battery is disconnected?
- ThePotatoLord
When I tested the JST connectors, I got 1.6 M omega. The switch is still attached, but I don't think that should make much of a difference.
Send a note to [email protected] with a link to this thread and the folks there will get you a replacement PowerBoost 500. (#1903)
- flipper2497
I have a similar problem. Im not sure if this is the Power Boost 500 Basic or the Micro Lipo w/MicroUSB. I checked every output and there was zero voltage there is no voltage going the the Power Boost 500 Basic. I purchase all the parts for the Pigrrl on 4/20/2015 order number 766602-6230919580.
- IMG_2668.JPG (380.02 KiB) Viewed 399 times
- IMG_2667.JPG (406.31 KiB) Viewed 399 times
Check the resistance with the battery disconnected and no power to the board.
- koolwinter
Hey i have a similar issue to these, my piboy will work when the battery, lipo and powerboost are not connected, when i power the pi normally but when attached doesnt power on either way. Also i was trying to do research on the problem and everyones powerboost seems to light up when battery/ lipo connect to it but mine doesnt it doesnt a very quick flash during plugging in but no more what could be my problem? Is it the powerboost?
i posted a short video of my problem at: http://www.youtube.com/watch?v=FK9CMnKPSvg
photos of connections:
http://tinypic.com/r/24quxpi/8
http://tinypic.com/r/214tkbn/8
My parts were purchased 04/Feb/15 invoice no.698017
In the video, the JST connector isn't fully seated in the jack. You may be getting intermittent supply power.
