Hi everybody !
I did this tutorial : https://learn.adafruit.com/adafruit-ult ... rything-up
All is ok but when i typed cgps -s, i have "no fix" error ...
but the led is brighting every 15 sec ..
(Hardware :
https://www.adafruit.com/products/746
https://www.adafruit.com/products/960
https://www.adafruit.com/products/851
) and a TTL cable ..
Regards.
PS : i just trying hte UART connection and i have the same result ...
Adafruit Ultimate GPS on the Raspberry Pi
- adafruit_support_rick
Re: Adafruit Ultimate GPS on the Raspberry Pi
Can you post a sample of the NMEA sentences you're seeing?
- benjinight
How ? with the sudo cat command ?
Regards.
Regards.
Yes. cat /dev/ttyAMA0 to a file
- benjinight
I just typing "sudo cat /dev/ttyAMA0" in the console and ... nothing ;(
I tried again with the TTL Cable (this http://www.4dsystems.com.au/product/4D- ... ing-Cable/)
1 wire on the RX/RX, 1 on the TX/RX, 1 on the 5V/Vin and the last GND/GND and the same result ... again
Regards
Regards
Please email [email protected] with a link to this thread for a replacement GPS module
- stan_qaz
Since you will be doing an exchange have you considered a GPS Hat instead of the chip module? It is a good bit less work to get it going.
https://www.adafruit.com/products/2324
