Title says it -- how do I rotate the image on my 800x480 Kippah display 90 degrees (or 270 degrees, to portrait mode)?
For the PiTFT displays, it was an option in the dtoverlay line in /boot/config.txt
Hoping there's something similar for the Kippah!
Looks great, much less room required than using an HDMI display and chopping up cables!
--bob
Rotating Kippah 90 degrees?
- fhlipzero
Re: Rotating Kippah 90 degrees?
for the Kippah it's about the same, one of these should do it for you
display_rotate rotates the display clockwise on the screen (default=0) or flips the display.
display_rotate=0 Normal
display_rotate=1 90 degrees
display_rotate=2 180 degrees
display_rotate=3 270 degrees
display_rotate=0x10000 horizontal flip
display_rotate=0x20000 vertical flip
- k6rtm
Many thanks -- worked a treat.
Moving my Kippo Honeypot from an older Pi B to a Pi 2 with 800x480 display
--bob
--bob
- fhlipzero
no problem, you are running Kali by chance are you? I just did a pi 2 running Kali and a kippah with a 7in tft and am getting a blue shade over my screen, no idea what's doing it
- k6rtm
Nope, running a Kippo variant under standard Raspbian on a Pi 2. So far so good, other than not having I2C for my other goodies, but not having to worry about HDMI board and cables makes up for it.fhlipzero wrote:no problem, you are running Kali by chance are you? I just did a pi 2 running Kali and a kippah with a 7in tft and am getting a blue shade over my screen, no idea what's doing it
