Hello, I have been trying to get my Adafruit PL2303TA USB to console cable to connect yo my new PI2 and cannot get it to work. Here is how it is connected:
I am using the latest version of Raspbian, Downloaded Prolific 1.10 driver, tested on Win 8 and Win 7.
Putty COM settings were:
Speed = 11500
Data Bits = 8
Stop Bits = 1
Parity = None
Flow Control = XON/XOFF (Also tried None)
Anything obvious as to why this is not connecting?
PI2 and PL2303TA Console
Re: PI2 and PL2303TA Console
Your connections look right.
Try a loopback test to make sure your computer is talking to the cable.. disconnect everything from the RasPi and plug a jumper between the TX and RX lines. Anything you send out should come back as input.
- paulf8080
This is always confusing to me. The console says TX is an output. Does the PI say TX is an output, too? If so, the wires should be crossed. TX>RX and RX<TX
- OHTorx
adafruit_support_mike wrote:Your connections look right.
I created the loopback and I got my text echo'd to me.
- OHTorx
paulf8080 wrote:This is always confusing to me. The console says TX is an output. Does the PI say TX is an output, too? If so, the wires should be crossed. TX>RX and RX<TX
I agree, I could not find documentation on if White = "connect to TxD" or White = "TxD and you need to connect it to target RxD"
UART connections work like a telephone: TX is the part you talk into, RX is the part you listen to.
To make two devices communicate, you have to connect the "talks into" to the "listens to". Connecting TX/TX and RX/RX is like shouting into someone's mouth and listening to their ear.
- OHTorx
adafruit_support_mike wrote:UART connections work like a telephone: TX is the part you talk into, RX is the part you listen to.
I fully understand Rxd and Txd seeing how I am the only guy that gets shipped out to make custom Serial cables in our warehouses. My point was around there is no documentation stating the white wire is the PL2303TA 's Tx or Rx lead. If I am missing this please let me know where it is.
Now back to my original question with connecting to the PI... if a loop back works is there something that has to be enabled on the PI? Is my picture of the connections accurate? My notes on the right 'Serial White to TxD' is based off a adafruit learning blog.
Your connections are right.
The RasPi's Serial console does have to be enabled at boot time, but that's the default option. If you aren't sure, run `sudo raspi-config` and explicity enable it.
- OHTorx
Ran the raspi-config, enabled it yet no console access. Any other suggestions?
Let's make sure it took.. if you enter `dmesg | grep AMA0`, do you get a line like:
[ 1.101789] console [ttyAMA0] enabled
- dbred4321
I could not get the serial com 7 port to work with Putty. I used the 168.192.x.xx address of the PI.
The serial console isn't a network connection. It's a hardware connection to the RasPi's UART/Serial pins:
https://learn.adafruit.com/adafruits-ra ... sole-cable
- OHTorx
I actually got nothing. Tried on another PI and got results. So Looks like I got a bad Pi or zapped it some how.adafruit_support_mike wrote:Let's make sure it took.. if you enter `dmesg | grep AMA0`, do you get a line like:
Thanks for all the help. I hope this helps others in the future.
