Pi 2 + PiTFT Plus 2.8" (ID:2423) black display
RomeoFox
Post by RomeoFox »
I bought an Adafruit PiTFT PLUS 2.8 (ID:2423) with capacitive touchscreen for my pi 2 and can't get it working. It stays black as if its not powered at all.
I tried:
a) Easy-Install-image and DIY Installer script from here: https://learn.adafruit.com/adafruit-2-8 ... sy-install
b) with raspbian following this post: http://forums.adafruit.com/viewtopic.php?f=47&t=68221
c) with raspbian like this: https://github.com/notro/fbtft/wiki
with many combinations...
Is anybody out there who has succeeded?
My DMESG after b) looks like:
[  361.857911] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[  361.863566] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
[  361.864764] fbtft_device:  SPI devices registered:
[  361.864791] fbtft_device:      spidev spi0.0 500kHz 8 bits mode=0x00
[  361.864808] fbtft_device:      spidev spi0.1 500kHz 8 bits mode=0x00
[  361.864820] fbtft_device:  'fb' Platform devices registered:
[  361.864855] fbtft_device:      bcm2708_fb id=-1 pdata? no
[  361.864905] fbtft_device: Deleting spi0.0
[  361.865454] fbtft_device:  GPIOS used by 'pitft':
[  361.865474] fbtft_device:    'dc' = GPIO25
[  361.865485] fbtft_device:  SPI devices registered:
[  361.865501] fbtft_device:      spidev spi0.1 500kHz 8 bits mode=0x00
[  361.865518] fbtft_device:      fb_ili9340 spi0.0 32000kHz 8 bits mode=0x00
[  361.881783] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[  362.053793] graphics fb1: fb_ili9340 frame buffer, 240x320, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
adafruit_support_rick
Re: Pi 2 + PiTFT Plus 2.8" (ID:2441) black display
Check that the flex cable is fully seated an secured in the connector:
https://learn.adafruit.com/adafruit-pit ... faq#faq-12
RomeoFox
Post by RomeoFox »
Checked, looks like in the picture.
Re: Pi 2 + PiTFT Plus 2.8" (ID:2423) black display
Please email [email protected] with a link to this thread for a replacement PiTFT
Return to “Adafruit Raspberry Pi® accessories”
