Product: Assembled PiTFT 3.5" Display
Order #:885336
Purchase Date: Sep 29, 2015
Recently I replaced my 3.5" PiTFT screen because my original screen arrived and it was damaged and would not (part of the flex connector going to the screen was broken). I then ordered a replacement and when I switched out the screens I found that the screen was always stuck on a white screen even after I followed both the easy install and the detailed install (both on clean installs of Raspian). I also tried installing the ROM provided on the install page of the PiTFT 3.5" screen and still no luck.
/dev/fb1 does exist and I can start the x server on it but nothing shows up. Essentially the pi acts as if the screen is there but nothing happens From googling around what I have come up with is that the kernel is not finding the PiTFT.
Anyone have an idea to fix this?
PiTFT White Screen
- adafruit_support_rick
Re: PiTFT White Screen
please post the output of the command sudo dmesg
- Cobbleopolis
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.6-v7+ (root@vagrant-ubuntu-trusty-32) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #2 SMP PREEMPT Fri Sep 4 16:49:07 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 8085af80, node_mem_map b9fa6000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b9f64000 s20608 r8192 d24448 u53248
[ 0.000000] pcpu-alloc: s20608 r8192 d24448 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2709.boardrev=0xa21041 bcm2709.serial=0xcf20ae18 smsc95xx.macaddr=B8:27:EB:20:AE:18 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:VGA8x8
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939512K/966656K available (5958K kernel code, 534K rwdata, 1644K rodata, 420K init, 757K bss, 18952K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80774c6c (7604 kB)
[ 0.000000] .init : 0x80775000 - 0x807de000 ( 420 kB)
[ 0.000000] .data : 0x807de000 - 0x80863af4 ( 535 kB)
[ 0.000000] .bss : 0x80866000 - 0x8092378c ( 758 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000032] Switching to timer-based delay loop, resolution 52ns
[ 0.000314] Console: colour dummy device 80x30
[ 0.002181] console [tty1] enabled
[ 0.002250] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.002351] pid_max: default: 32768 minimum: 301
[ 0.002719] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002788] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004093] Initializing cgroup subsys blkio
[ 0.004177] Initializing cgroup subsys memory
[ 0.004248] Initializing cgroup subsys devices
[ 0.004309] Initializing cgroup subsys freezer
[ 0.004383] Initializing cgroup subsys net_cls
[ 0.004496] CPU: Testing write buffer coherency: ok
[ 0.004617] ftrace: allocating 20203 entries in 60 pages
[ 0.054144] CPU0: update cpu_capacity 1024
[ 0.054228] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.054276] [bcm2709_smp_prepare_cpus] enter
[ 0.054434] Setting up static identity map for 0x8240 - 0x8274
[ 0.114018] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.114326] [bcm2709_secondary_init] enter cpu:1
[ 0.114378] CPU1: update cpu_capacity 1024
[ 0.114387] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.134001] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.134253] [bcm2709_secondary_init] enter cpu:2
[ 0.134284] CPU2: update cpu_capacity 1024
[ 0.134292] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.154037] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.154217] [bcm2709_secondary_init] enter cpu:3
[ 0.154247] CPU3: update cpu_capacity 1024
[ 0.154255] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.154347] Brought up 4 CPUs
[ 0.154482] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.154524] CPU: All CPU(s) started in SVC mode.
[ 0.155549] devtmpfs: initialized
[ 0.180601] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.180964] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.182162] pinctrl core: initialized pinctrl subsystem
[ 0.183003] NET: Registered protocol family 16
[ 0.188812] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.190088] bcm2709.uart_clock = 3000000
[ 0.195471] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.195543] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.195784] Serial: AMBA PL011 UART driver
[ 0.196002] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.699868] console [ttyAMA0] enabled
[ 0.704149] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.786415] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x7f35
[ 0.795261] bcm2708-dmaengine 3f007000.dma: failed to get irq for DMA channel 13
[ 0.802703] bcm2708-dmaengine 3f007000.dma: Initialized 8 DMA channels (+ 1 legacy)
[ 0.811234] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.818140] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.824140] SCSI subsystem initialized
[ 0.828154] usbcore: registered new interface driver usbfs
[ 0.833792] usbcore: registered new interface driver hub
[ 0.839269] usbcore: registered new device driver usb
[ 0.845068] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-09-02 14:55
[ 0.880654] Switched to clocksource arch_sys_counter
[ 0.935909] FS-Cache: Loaded
[ 0.939198] CacheFiles: Loaded
[ 0.954030] NET: Registered protocol family 2
[ 0.959736] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.967003] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.973721] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.980214] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.986245] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.993006] NET: Registered protocol family 1
[ 0.997807] RPC: Registered named UNIX socket transport module.
[ 1.003837] RPC: Registered udp transport module.
[ 1.008565] RPC: Registered tcp transport module.
[ 1.013309] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.021059] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 1.030569] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.052918] VFS: Disk quotas dquot_6.6.0
[ 1.057242] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.066811] FS-Cache: Netfs 'nfs' registered for caching
[ 1.073328] NFS: Registering the id_resolver key type
[ 1.078462] Key type id_resolver registered
[ 1.082740] Key type id_legacy registered
[ 1.089595] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.097268] io scheduler noop registered
[ 1.101310] io scheduler deadline registered (default)
[ 1.106807] io scheduler cfq registered
[ 1.113265] BCM2708FB: allocated DMA memory fac00000
[ 1.118293] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.153984] Console: switching to colour frame buffer device 228x123
[ 1.179240] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[ 1.187024] vc-cma: Videocore CMA driver
[ 1.191038] vc-cma: vc_cma_base = 0x00000000
[ 1.195796] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.201274] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.206979] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.231458] brd: module loaded
[ 1.243649] loop: module loaded
[ 1.247927] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 1.256834] Loading iSCSI transport class v2.0-870.
[ 1.262776] usbcore: registered new interface driver smsc95xx
[ 1.268685] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.474907] Core Release: 2.80a
[ 1.478103] Setting default values for core params
[ 1.483028] Finished setting default values for core params
[ 1.689068] Using Buffer DMA mode
[ 1.692455] Periodic Transfer Interrupt Enhancement - disabled
[ 1.698349] Multiprocessor Interrupt Enhancement - disabled
[ 1.704005] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.708415] Dedicated Tx FIFOs mode
[ 1.712353] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 1.722351] FIQ FSM acceleration enabled for :
[ 1.722351] Non-periodic Split Transactions
[ 1.722351] Periodic Split Transactions
[ 1.722351] High-Speed Isochronous Endpoints
[ 1.739282] dwc_otg: Microframe scheduler enabled
[ 1.739366] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x8040137c
[ 1.745362] WARN::hcd_init_fiq:413: FIQ ASM at 0x804016d8 length 36
[ 1.751701] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89a000
[ 1.757807] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.762901] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.770322] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 1.776025] Init: Port Power? op_state=1
[ 1.779994] Init: Power Port (0)
[ 1.783592] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.790462] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.797792] usb usb1: Product: DWC OTG Controller
[ 1.802579] usb usb1: Manufacturer: Linux 4.1.6-v7+ dwc_otg_hcd
[ 1.808567] usb usb1: SerialNumber: 3f980000.usb
[ 1.814196] hub 1-0:1.0: USB hub found
[ 1.818066] hub 1-0:1.0: 1 port detected
[ 1.822603] dwc_otg: FIQ enabled
[ 1.822618] dwc_otg: NAK holdoff enabled
[ 1.822629] dwc_otg: FIQ split-transaction FSM enabled
[ 1.822670] Module dwc_common_port init
[ 1.823067] usbcore: registered new interface driver usb-storage
[ 1.829429] mousedev: PS/2 mouse device common for all mice
[ 1.836021] bcm2835-cpufreq: min=600000 max=1000000
[ 1.841365] sdhci: Secure Digital Host Controller Interface driver
[ 1.847619] sdhci: Copyright(c) Pierre Ossman
[ 1.852514] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.858423] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 1.901027] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.911856] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.918229] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.924060] usbcore: registered new interface driver usbhid
[ 1.930825] usbhid: USB HID core driver
[ 1.936205] Initializing XFRM netlink socket
[ 1.940668] NET: Registered protocol family 17
[ 1.948680] Key type dns_resolver registered
[ 1.953693] Registering SWP/SWPB emulation handler
[ 1.959505] registered taskstats version 1
[ 1.963962] vc-sm: Videocore shared memory driver
[ 1.968734] [vc_sm_connected_init]: start
[ 1.973681] [vc_sm_connected_init]: end - returning 0
[ 1.980774] Waiting for root device /dev/mmcblk0p2...
[ 1.989379] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.001118] mmc0: new high speed SDHC card at address aaaa
[ 2.007285] mmcblk0: mmc0:aaaa SL32G 28.7 GiB
[ 2.015496] mmcblk0: p1 p2
[ 2.020806] Indeed it is in host mode hprt0 = 00021501
[ 2.123946] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.132326] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.140315] devtmpfs: mounted
[ 2.144136] Freeing unused kernel memory: 420K (80775000 - 807de000)
[ 2.200751] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.207598] Indeed it is in host mode hprt0 = 00001101
[ 2.411128] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.417959] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.426141] hub 1-1:1.0: USB hub found
[ 2.430105] hub 1-1:1.0: 5 ports detected
[ 2.710784] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.831281] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.838285] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.851875] smsc95xx v1.0.4
[ 2.915597] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:20:ae:18
[ 3.030800] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 3.168669] usb 1-1.3: New USB device found, idVendor=148f, idProduct=5370
[ 3.190723] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.204248] usb 1-1.3: Product: 802.11 n WLAN
[ 3.217727] usb 1-1.3: Manufacturer: Ralink
[ 3.230327] usb 1-1.3: SerialNumber: 1.0
[ 3.353429] udevd[175]: starting version 175
[ 3.480848] usb 1-1.5: new low-speed USB device number 5 using dwc_otg
[ 3.622758] usb 1-1.5: New USB device found, idVendor=0c40, idProduct=8000
[ 3.636088] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.651834] usb 1-1.5: Product: 2.4GHz receiver
[ 3.664312] usb 1-1.5: Manufacturer: ELMCU
[ 3.694793] input: ELMCU 2.4GHz receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:0C40:8000.0001/input/input0
[ 3.771365] hid-generic 0003:0C40:8000.0001: input,hidraw0: USB HID v1.11 Keyboard [ELMCU 2.4GHz receiver] on usb-3f980000.usb-1.5/input0
[ 3.808585] input: ELMCU 2.4GHz receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:0C40:8000.0002/input/input1
[ 3.901843] hid-generic 0003:0C40:8000.0002: input,hidraw1: USB HID v1.11 Mouse [ELMCU 2.4GHz receiver] on usb-3f980000.usb-1.5/input1
[ 4.051071] spi spi0.1: setting up native-CS1 as GPIO 7
[ 4.075401] stmpe-spi spi0.1: stmpe610 detected, chip id: 0x811
[ 4.121988] spi spi0.0: setting up native-CS0 as GPIO 8
[ 4.369767] cfg80211: Calling CRDA to update world regulatory domain
[ 4.403531] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.431823] fb_hx8357d: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.456757] fbtft_of_value: buswidth = 8
[ 4.469167] fbtft_of_value: debug = 0
[ 4.491680] fbtft_of_value: rotate = 90
[ 4.505828] fbtft_of_value: fps = 20
[ 4.620740] usb 1-1.3: reset high-speed USB device number 4 using dwc_otg
[ 4.761445] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[ 4.798175] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[ 4.833858] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 4.836021] usbcore: registered new interface driver rt2800usb
[ 5.223560] graphics fb1: fb_hx8357d frame buffer, 480x320, 300 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 42 MHz
[ 5.537206] random: nonblocking pool is initialized
[ 6.660163] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.031412] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.540892] cfg80211: Calling CRDA to update world regulatory domain
[ 7.631417] input: stmpe-ts as /devices/platform/soc/3f204000.spi/spi_master/spi0/spi0.1/stmpe-ts/input/input2
[ 10.710856] cfg80211: Calling CRDA to update world regulatory domain
[ 12.052139] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 12.054633] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
[ 12.495636] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 13.880883] cfg80211: Calling CRDA to update world regulatory domain
[ 13.943703] wlan0: authenticate with 94:10:3e:a9:60:1a
[ 14.010497] wlan0: send auth to 94:10:3e:a9:60:1a (try 1/3)
[ 14.012193] wlan0: authenticated
[ 14.013104] rt2800usb 1-1.3:1.0 wlan0: disabling HT/VHT due to WEP/TKIP use
[ 14.020817] wlan0: associate with 94:10:3e:a9:60:1a (try 1/3)
[ 14.025086] wlan0: RX AssocResp from 94:10:3e:a9:60:1a (capab=0x411 status=0 aid=7)
[ 14.034307] wlan0: associated
[ 17.040713] cfg80211: Calling CRDA to update world regulatory domain
[ 17.089149] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2134012k SSFS
[ 20.200689] cfg80211: Calling CRDA to update world regulatory domain
[ 23.158956] uart-pl011 3f201000.uart: no DMA platform data
[ 23.360787] cfg80211: Calling CRDA to update world regulatory domain
[ 26.520687] cfg80211: Calling CRDA to update world regulatory domain
[ 29.680750] cfg80211: Calling CRDA to update world regulatory domain
[ 32.840733] cfg80211: Calling CRDA to update world regulatory domain
[ 36.000682] cfg80211: Calling CRDA to update world regulatory domain
[ 39.160734] cfg80211: Exceeded CRDA call max attempts. Not calling CRDA
[ 354.910711] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
[ 355.016262] usb 1-1.2: New USB device found, idVendor=05dc, idProduct=a838
[ 355.016289] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 355.016306] usb 1-1.2: Product: USB Flash Drive
[ 355.016322] usb 1-1.2: Manufacturer: Lexar
[ 355.016339] usb 1-1.2: SerialNumber: AAU08UEYQ6DK3714
[ 355.018217] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 355.018789] scsi host0: usb-storage 1-1.2:1.0
[ 356.177808] scsi 0:0:0:0: Direct-Access Lexar USB Flash Drive 1100 PQ: 0 ANSI: 6
[ 356.179682] sd 0:0:0:0: [sda] 31285248 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 356.180527] sd 0:0:0:0: [sda] Write Protect is off
[ 356.180549] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 356.181454] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 356.188086] sda: sda1
[ 356.192033] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 356.200801] sd 0:0:0:0: Attached scsi generic sg0 type 0
The PiTFT drivers are loading correctly. Check that the flex connector is fully inserted and secured on the back of the PiTFT:
https://learn.adafruit.com/adafruit-pit ... faq#faq-12
- Cobbleopolis
Yes the flex connector is correctly inserted and secured.
Please email [email protected] with a link to this thread for a replacement PiTFT
