RE the PiTFT Plus 480x320 3.5" TFT+Touchscreen PID #2097
I've tried - but the only way I can fit this into my project is upside-down.
I'm installing this into a gameboy case with a Pi2. I intend to run Retropi.
Is there a way to configure this display to be run in this configuration?
PiTFT 3.5" TFT - I want to install this upside down
- StuartFox
- StuartFox
Re: PiTFT 3.5" TFT - I want to install this upside down
Hi again,
So forgetting about making the screen work upside down, I can't even get it working at all with RetroPi (I've tested it with the image and it works fine so there's nothing wrong with the display)
Ok - so I've gone through the instructions to install the TFT drivers.
After downloading and installing everything I get an error message on bootup:
Failed (code8).
[FAIL] File system check failed. A log is being saved in /var/log/fsck/checkfs if that location is writable. Please repair the file system manually. ... failed!
[warn] a maintenance shell will now be started. CONTROL-D will terminate this shell and resule system boot. ... (warning).
sulogin: root account is locked, starting shell
Failed (code8).
- adafruit_support_rick
Can you start over on installing RetroPi? Clearly, something has gone wrong and trashed the file system.
- StuartFox
Ok, I'll start again, but I'm confused as to which guide I should be using.
Already made the latest retropie image and then followed the steps here:
https://learn.adafruit.com/adafruit-pit ... ed-install
There are also specific retropie instructions here:
https://learn.adafruit.com/running-open ... s/overview
But the note says these no longer work. Is there an ujpdated version of the latter guide that does work?
Let's try to narrow it down a little.
When go through this step up to the reboot, does the screen go white and then turn black?
https://learn.adafruit.com/adafruit-pit ... all-kernel
If not, can you post the results of sudo dmesg at that point?
- StuartFox
Went through the steps up to the reboot - the screen stayed white the whole time.
Below are the results as requested. Many thanks.
pi@retropie ~ $ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.6-v7+ (root@vagrant-ubuntu-trusty-32) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #2 SMP PREEMPT Fri Sep 4 16:49:07 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 8085af80, node_mem_map ae156000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @ae115000 s20608 r8192 d24448 u53248
[ 0.000000] pcpu-alloc: s20608 r8192 d24448 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1600 bcm2708_fb.fbheight=1200 bcm2709.boardrev=0xa01041 bcm2709.serial=0x9f684630 smsc95xx.macaddr=B8:27:EB:68:46:30 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 744636K/770048K available (5958K kernel code, 534K rwdata, 1644K rodata, 420K init, 757K bss, 17220K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xaf800000 - 0xff000000 (1272 MB)
[ 0.000000] lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80774c6c (7604 kB)
[ 0.000000] .init : 0x80775000 - 0x807de000 ( 420 kB)
[ 0.000000] .data : 0x807de000 - 0x80863af4 ( 535 kB)
[ 0.000000] .bss : 0x80866000 - 0x8092378c ( 758 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000032] Switching to timer-based delay loop, resolution 52ns
[ 0.000317] Console: colour dummy device 80x30
[ 0.002106] console [tty1] enabled
[ 0.002172] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.002274] pid_max: default: 32768 minimum: 301
[ 0.002640] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002708] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004022] Initializing cgroup subsys blkio
[ 0.004107] Initializing cgroup subsys memory
[ 0.004178] Initializing cgroup subsys devices
[ 0.004239] Initializing cgroup subsys freezer
[ 0.004311] Initializing cgroup subsys net_cls
[ 0.004421] CPU: Testing write buffer coherency: ok
[ 0.004544] ftrace: allocating 20203 entries in 60 pages
[ 0.054093] CPU0: update cpu_capacity 1024
[ 0.054179] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.054228] [bcm2709_smp_prepare_cpus] enter
[ 0.054389] Setting up static identity map for 0x8240 - 0x8274
[ 0.113990] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.114292] [bcm2709_secondary_init] enter cpu:1
[ 0.114345] CPU1: update cpu_capacity 1024
[ 0.114353] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.133978] [bcm2709_boot_secondary] cpu:2 started (0) 16
[ 0.134229] [bcm2709_secondary_init] enter cpu:2
[ 0.134260] CPU2: update cpu_capacity 1024
[ 0.134268] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.154013] [bcm2709_boot_secondary] cpu:3 started (0) 16
[ 0.154191] [bcm2709_secondary_init] enter cpu:3
[ 0.154220] CPU3: update cpu_capacity 1024
[ 0.154228] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.154322] Brought up 4 CPUs
[ 0.154456] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.154499] CPU: All CPU(s) started in SVC mode.
[ 0.155549] devtmpfs: initialized
[ 0.180136] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.180503] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.181715] pinctrl core: initialized pinctrl subsystem
[ 0.182546] NET: Registered protocol family 16
[ 0.188330] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.189583] bcm2709.uart_clock = 3000000
[ 0.194594] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.194665] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.194888] Serial: AMBA PL011 UART driver
[ 0.195116] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.698285] console [ttyAMA0] enabled
[ 0.702561] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.776360] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x7f35
[ 0.785205] bcm2708-dmaengine 3f007000.dma: failed to get irq for DMA channel 13
[ 0.792656] bcm2708-dmaengine 3f007000.dma: Initialized 8 DMA channels (+ 1 legacy)
[ 0.801171] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.808078] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.814076] SCSI subsystem initialized
[ 0.818088] usbcore: registered new interface driver usbfs
[ 0.823731] usbcore: registered new interface driver hub
[ 0.829215] usbcore: registered new device driver usb
[ 0.835013] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-09-02 14:55
[ 0.870563] Switched to clocksource arch_sys_counter
[ 0.925811] FS-Cache: Loaded
[ 0.929086] CacheFiles: Loaded
[ 0.944059] NET: Registered protocol family 2
[ 0.949766] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.957039] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.963754] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.970247] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.976275] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.983034] NET: Registered protocol family 1
[ 0.987849] RPC: Registered named UNIX socket transport module.
[ 0.993882] RPC: Registered udp transport module.
[ 0.998610] RPC: Registered tcp transport module.
[ 1.003355] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.011064] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 1.020665] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.042877] VFS: Disk quotas dquot_6.6.0
[ 1.047199] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.056868] FS-Cache: Netfs 'nfs' registered for caching
[ 1.063376] NFS: Registering the id_resolver key type
[ 1.068560] Key type id_resolver registered
[ 1.072836] Key type id_legacy registered
[ 1.079689] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.087360] io scheduler noop registered
[ 1.091402] io scheduler deadline registered (default)
[ 1.096903] io scheduler cfq registered
[ 1.103347] BCM2708FB: allocated DMA memory eec00000
[ 1.108374] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.145390] Console: switching to colour frame buffer device 200x75
[ 1.171541] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[ 1.178608] KGDB: Registered I/O driver kgdboc
[ 1.211337] vc-cma: Videocore CMA driver
[ 1.215348] vc-cma: vc_cma_base = 0x00000000
[ 1.220139] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.225664] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.231423] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.255891] brd: module loaded
[ 1.268122] loop: module loaded
[ 1.272466] vchiq: vchiq_init_state: slot_zero = 0xaec80000, is_master = 0
[ 1.281359] Loading iSCSI transport class v2.0-870.
[ 1.287342] usbcore: registered new interface driver smsc95xx
[ 1.293329] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.499542] Core Release: 2.80a
[ 1.502796] Setting default values for core params
[ 1.507717] Finished setting default values for core params
[ 1.713823] Using Buffer DMA mode
[ 1.717215] Periodic Transfer Interrupt Enhancement - disabled
[ 1.723214] Multiprocessor Interrupt Enhancement - disabled
[ 1.728891] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.733361] Dedicated Tx FIFOs mode
[ 1.737295] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xaec14000 dma = 0xeec14000 len=9024
[ 1.747364] FIQ FSM acceleration enabled for :
[ 1.747364] Non-periodic Split Transactions
[ 1.747364] Periodic Split Transactions
[ 1.747364] High-Speed Isochronous Endpoints
[ 1.764386] dwc_otg: Microframe scheduler enabled
[ 1.764481] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x8040137c
[ 1.770519] WARN::hcd_init_fiq:413: FIQ ASM at 0x804016d8 length 36
[ 1.776905] WARN::hcd_init_fiq:438: MPHI regs_base at 0xaf89a000
[ 1.783057] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.788160] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.795667] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 1.801411] Init: Port Power? op_state=1
[ 1.805409] Init: Power Port (0)
[ 1.809002] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.815952] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.823335] usb usb1: Product: DWC OTG Controller
[ 1.828132] usb usb1: Manufacturer: Linux 4.1.6-v7+ dwc_otg_hcd
[ 1.834186] usb usb1: SerialNumber: 3f980000.usb
[ 1.839809] hub 1-0:1.0: USB hub found
[ 1.849488] hub 1-0:1.0: 1 port detected
[ 1.859660] dwc_otg: FIQ enabled
[ 1.859675] dwc_otg: NAK holdoff enabled
[ 1.859687] dwc_otg: FIQ split-transaction FSM enabled
[ 1.859730] Module dwc_common_port init
[ 1.860133] usbcore: registered new interface driver usb-storage
[ 1.872296] mousedev: PS/2 mouse device common for all mice
[ 1.884578] bcm2835-cpufreq: min=600000 max=900000
[ 1.895547] sdhci: Secure Digital Host Controller Interface driver
[ 1.907507] sdhci: Copyright(c) Pierre Ossman
[ 1.918088] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.929750] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 1.980930] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.997531] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.010661] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.023223] usbcore: registered new interface driver usbhid
[ 2.035712] usbhid: USB HID core driver
[ 2.046810] Initializing XFRM netlink socket
[ 2.050726] Indeed it is in host mode hprt0 = 00021501
[ 2.068855] NET: Registered protocol family 17
[ 2.081361] Key type dns_resolver registered
[ 2.091915] Registering SWP/SWPB emulation handler
[ 2.103416] registered taskstats version 1
[ 2.113486] vc-sm: Videocore shared memory driver
[ 2.123956] [vc_sm_connected_init]: start
[ 2.134616] [vc_sm_connected_init]: end - returning 0
[ 2.147604] Waiting for root device /dev/mmcblk0p2...
[ 2.163146] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.179913] mmc0: new high speed SDHC card at address aaaa
[ 2.191746] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[ 2.203435] mmcblk0: p1 p2
[ 2.230627] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.243151] Indeed it is in host mode hprt0 = 00001101
[ 2.262828] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.275940] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.450982] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.463609] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.477508] hub 1-1:1.0: USB hub found
[ 2.487243] hub 1-1:1.0: 5 ports detected
[ 2.757448] EXT4-fs (mmcblk0p2): recovery complete
[ 2.770608] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.776231] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.776295] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.777081] devtmpfs: mounted
[ 2.777807] Freeing unused kernel memory: 420K (80775000 - 807de000)
[ 2.931022] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.944659] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.961892] smsc95xx v1.0.4
[ 3.035573] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:68:46:30
[ 3.290700] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.409882] usb 1-1.2: New USB device found, idVendor=05ac, idProduct=1006
[ 3.424851] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.442454] usb 1-1.2: Product: Keyboard Hub
[ 3.453419] usb 1-1.2: Manufacturer: Apple, Inc.
[ 3.465558] usb 1-1.2: SerialNumber: 000000000000
[ 3.478261] hub 1-1.2:1.0: USB hub found
[ 3.489013] hub 1-1.2:1.0: 3 ports detected
[ 3.580705] usb 1-1.4: new high-speed USB device number 5 using dwc_otg
[ 3.594583] hub 1-1.2:1.0: hub_port_status failed (err = -71)
[ 3.606786] hub 1-1.2:1.0: hub_port_status failed (err = -71)
[ 3.618892] hub 1-1.2:1.0: hub_port_status failed (err = -71)
[ 3.712711] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8176
[ 3.728352] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.742632] usb 1-1.4: Product: 802.11n WLAN Adapter
[ 3.754426] usb 1-1.4: Manufacturer: Realtek
[ 3.765596] usb 1-1.4: SerialNumber: 00e04c000001
[ 3.780137] usb 1-1.2: USB disconnect, device number 4
[ 3.997993] udevd[175]: starting version 175
[ 4.030684] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
[ 4.149846] usb 1-1.2: New USB device found, idVendor=05ac, idProduct=1006
[ 4.163675] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.178013] usb 1-1.2: Product: Keyboard Hub
[ 4.188978] usb 1-1.2: Manufacturer: Apple, Inc.
[ 4.200425] usb 1-1.2: SerialNumber: 000000000000
[ 4.212887] hub 1-1.2:1.0: USB hub found
[ 4.224543] hub 1-1.2:1.0: 3 ports detected
[ 4.331122] hub 1-1.2:1.0: hub_port_status failed (err = -71)
[ 4.348051] hub 1-1.2:1.0: hub_port_status failed (err = -71)
[ 4.365832] hub 1-1.2:1.0: hub_port_status failed (err = -71)
[ 4.485366] usb 1-1.2: USB disconnect, device number 6
[ 4.740832] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
[ 4.840994] random: nonblocking pool is initialized
[ 4.879349] usb 1-1.2: New USB device found, idVendor=05ac, idProduct=1006
[ 4.892877] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.909673] usb 1-1.2: Product: Keyboard Hub
[ 4.922729] usb 1-1.2: Manufacturer: Apple, Inc.
[ 4.936231] usb 1-1.2: SerialNumber: 000000000000
[ 4.974380] usbcore: registered new interface driver rtl8192cu
[ 4.987778] hub 1-1.2:1.0: USB hub found
[ 4.998356] hub 1-1.2:1.0: 3 ports detected
[ 5.290697] usb 1-1.2.2: new low-speed USB device number 8 using dwc_otg
[ 5.420808] usb 1-1.2.2: New USB device found, idVendor=05ac, idProduct=0250
[ 5.434883] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.448998] usb 1-1.2.2: Product: Apple Keyboard
[ 5.460257] usb 1-1.2.2: Manufacturer: Apple Inc.
[ 5.533586] input: Apple Inc. Apple Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/0003:05AC:0250.0001/input/input0
[ 5.611648] apple 0003:05AC:0250.0001: input,hidraw0: USB HID v1.11 Keyboard [Apple Inc. Apple Keyboard] on usb-3f980000.usb-1.2.2/input0
[ 5.633896] input: Apple Inc. Apple Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.1/0003:05AC:0250.0002/input/input1
[ 5.711210] apple 0003:05AC:0250.0002: input,hidraw1: USB HID v1.11 Device [Apple Inc. Apple Keyboard] on usb-3f980000.usb-1.2.2/input1
[ 6.613962] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.954499] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 11.963763] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 13.977338] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
[ 15.478844] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 15.863648] uart-pl011 3f201000.uart: no DMA platform data
I don't see the display drivers loading. Did you get any errors from this?
sudo apt-get install raspberrypi-bootloader
- StuartFox
It seems I was also having firewall issues as well so there were certain errors that I didn't pick up on.
I've got to a point were the screen works in console mode, But as soon as Retropie or piplay start, the GUI and games run on the HDMI monitor, not the TFT.
To address this, steps from this giude : https://learn.adafruit.com/running-open ... opie-setup are needed are they not?
Thing is, this guide still says it does not work at the moment so is this my issue?
Is it even possible for me to run Emulationstation / Retropie or PiPlay on an adafruit TFT with a Pi2 right now?
This is the relevant page:
https://learn.adafruit.com/running-open ... itft-setup
The framebuffer mirroring is what makes RetroPi show up on the PiTFT.
As far as I know, it all works on a Pi 2. Just make sure you're using the latest RetroPi image.
- StuartFox
Thanks, I'll try again.
It says that the 3.5" tft is not recommended, is this still the case?
If it is ok to use now, would the name of the display be 35r?
- StuartFox
following the guide up to the point I get this error:
install: cannot create regular file '/usr/local/bin/fbcp': No such file or directory
- StuartFox
- StuartFox
Sorry to keep adding little bits, but the function get_mode() as described on that page doesn't exist in sudo nano /opt/retropie/supplementary/runcommand/runcommand.sh
- pburgess
What version # of RetroPie are you running? It's possible that something has changed in the runcommand.sh script or elsewhere. I can check but need to know the exact release you're using.
The 3.5" PiTFT is still not-recommended; with that many pixels, the refresh rate is something like 15-20 fps, tops. For gaming on anything larger than the 2.8" PiTFT, the best route would be a small HDMI display (composite video displays can work too, but may be a bit blurry).
- StuartFox
It's RetroPie 3.2.1 as downloaded today.
so I'm coming across this:
And this:
I have the Adafruit 3.5" composite TV PRODUCT ID: 913 which I've already modified to run from 5v as per your instructions on the gamegear pi page. That's my fall-back if this doesn't work. (I can always build a second later). RE HDMI, I understand it's not really recommended under 5".
Thanks again for the support so far.... Cheers.
And this:
