I just bought two 16-Channel PWM Hats for my Raspberry Pi 2 Model B+, separate the two hats work well but when i stack them and try to use both on the same Python code (The Servo_Example code) just one of them move the servos.
I change the adress of one hat but i don't know how to initialize them properly.
pwm = PWM (0X40)
pwm = PWM (0X41)
I need some help. Thanks.
Stack two 16-Channel PWM Hats
- GerardWassink
Re: Stack two 16-Channel PWM Hats
Perhaps you could use the gawServoHandler.py Library. I wrote it for my Servo Hat.
You can find it on my GitHub repository.
It sounds like an initialization problem.
The library initializes the board when it detects that another board is being addressed.
Let me know how it works for you.
Gerard
Gerard
- Marco01___
Check the code but same problem.
I just return to the Servo_Example code and change the lines
pwm = PWM(0x40)
pwm = PWM(0x41)
to
pwm1 = PWM(0x40)
pwm2 = PWM(0x41)
and create a objet for each one, change the instruction to move the servos from
pwm.setPWM(Channel,Address,Position)
to
pwm1.setPWM(Channel,0x40,Position)
or
pwm2.setPWM(Channel,0x41,Position)
Now the two hats work in a single Python Code.
Thanks.
pwm = PWM(0x40)
pwm = PWM(0x41)
to
pwm1 = PWM(0x40)
pwm2 = PWM(0x41)
to
or
Thanks.
