I have my HAT soldered up, connected, and code running on the Pi. If I run my finger along the HAT's alligator clip area, I get a response perfectly.
But when I clip on alligator clips, it will engage the sensor and never stop. So each sensor is running "high", and can't detect further interaction with the clip or anything attached to the clip.
Could I have made a mistake in soldering? It works perfectly with just finger touches.
Capacitive Touch HAT doesn't work with alligator clips
- thisisjohnbrown
- drewfustini
Re: Capacitive Touch HAT doesn't work with alligator clips
Please post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
- redwoodturner
I have exactly the same problem - using with a Pi2.
Board works perfectly withe touch, but any conducting items such as a croc clip causes the response to repeat until the item removed.
- adafruit_support_bill
@redwoodturner - Please post some photos showing your soldering and connections. 800x600 is a good size.
- redwoodturner
It's a HAT. What other connections do you expect? If you are suggesting it is a dry joint please let me know. What was your reply to the first person who queried the problem please?
derek
derek
We made exactly the same request as you can read above. The OP has not responded.What was your reply to the first person who queried the problem please?
The vast majority of problems are soldering related. We like to start with a a good view of the board.Please post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
- redwoodturner
Okay.
To reduce the possibilities, I have reduced it to a headless set up with only the power supply and headphones connected. As before the touch connections all respond correctly to a human touch, do not respond to an insulation touch but remain in a permanent loop when a conductor including a croc clip connected to any of the 12 connections. I attach a photo as requested.
- Attachments
- P1040753-00.jpg (151.5 KiB) Viewed 346 times
What are you connecting to the inputs and how long are the wires? The sensitivity of the input is roughly proportional to the surface area of the attached conductor - including the connecting wire. Large objects or long connecting wires can make the input hyper-sensitive to the point where it becomes unstable.
- redwoodturner
I've tried: a double ended croc clip lead 6" long, a scredriver with 6" arm and a single wire 2 " long.
- adafruit2
each object has some capacitance and the hat does calibration when you first run the software. so you can't 'live' connect stuff. you have to connect everything and *then* run the software. that way the capacitance of the cables is taken into account :)
- redwoodturner
Solved - great, thanks for this. Can't say that I understand what is going on mind you!
It might be useful to add this as a note in the tutorials for the hat.
- adafruit2
- rhydutsky
Hi sorry for no responded sooner. It was software, the additions to the tutorial are crucial thanks for adding them.
