How does one go about using two (or more) electrical components that use I2C on a Raspberry Pi 3?
The first component is Adafruit RGB Negative 16x2 LCD+Keypad Kit for Raspberry Pi (1110).
The next component is Stereo 2.8W Class D Audio Amplifier - I2C Control AGC - TPA2016 (1712)
I see in the description for the RGB LCD it states "lets you control a 16x2 Character LCD, up to 3 backlight pins AND 5 keypad pins using only the two I2C pins on the R-Pi! The best part is you don't really lose those two pins either, since you can stick i2c-based sensors, RTCs, etc and have them share the I2C bus. " I guess what I don't understand is how you do you physically add something else that those I2C pins since they are covered up.
Thank you for addressing this that even a newbie can understand.
Steve
Two components that use I2C on RPi 3
- adafruit_support_bill
Re: Two components that use I2C on RPi 3
If you use a Cobbler and a breadboard, you can make multiple connections on the breadboard. Otherwise, you can just splice some wires together and plug them into the Pi GPIO header.
- steve0429
Thank you for your answer. But if the 16x2 kit board plugs directly into the RPi via the "Raspberry Pi Plate Header" then is it ok to simply solder I2C wires from the 16x2 LED kit board side to continue the I2C to the other component that needs I2C?
Steve
Steve
That would work. Another option is to use stacking headers. https://www.adafruit.com/products/2223
