Questions about writing code for Gemma
Re: Questions about writing code for Gemma
by Crystal on Mon Sep 30, 2013 8:44 pm
I'm still wondering if the problem has something to do with my code. I changed the pin numbers to correspond to the pads on my Flora, uploaded the sketch, and I still can't get the NeoPixel LED to change color.
On the Flora, I used pin 6 for the NeoPixel and connected the switch to pin 1 (TX) and to GND. The switch didn't work, so I took it off and then just had a single jumper connected to pin 1. I alternated between touching the opposite end of the jumper to GND and to 3.3v, but nothing happened then either. The LED just stayed white and didn't change to the color of the next pattern...
Crystal
Re: Questions about writing code for Gemma RESOLVED!
by Crystal on Tue Oct 01, 2013 12:38 am
The problem was part of my code after all!
This:
    lightPattern == lightPattern + 1;
should be this:
    lightPattern = lightPattern + 1;
(And to give credit where credit is due, I didn't discover my mistake in the code myself; a kind soul on the Arduino forums pointed it out to me.)
I've since successfully uploaded the code to both Gemma and Flora, and everything seems to be working fine now. Thank you both, Bill and Rick, for all your help!
Crystal
by adafruit_support_bill on Tue Oct 01, 2013 5:30 am
Wow! I knew it had to be something simple, but I wasn't looking for that one.
The 'classic' mistake in C/C++ is just the opposite: Using '=' instead of '==' in a conditional statement.
