Is there a tutorial on how to get the flora lux sensor and leds to work together? I would like to set up a simple if then sketch where the less light received by the sensor the brighter the leds would shine. I'm using the flora, flora lux and the flora RGB Smart NeoPixel version 2 - Pack of 4
Flora lux sensor and LEDs
- Franklin97355
Re: Flora lux sensor and LEDs
What have you tried so far?I would like to set up a simple if then sketch where the less light received by the sensor the brighter the leds would shine.
- edwardiglesias
All I've done so far is run the sketch to get the leds blinking as in
https://learn.adafruit.com/getting-star ... a-projects
and wired up the sensor as in
https://learn.adafruit.com/flora-lux-sensor/programming
to make sure everything worked. This was my first issue. I have VBATT, D6 and GND taken and am unsure where to wire up the sensor. Other than that I have just used the example code and am unsure how to integrate an if/then loop for the sensor.
Thanks.
Thanks.
- Franklin97355
According to the tutorial you connect the sensor to gnd, 3.3, SDA, and SCL on the flora.
- edwardiglesias
This is the way I've rigged it up so far. I tried using the example code for the broach and that works. Unfortunately the code for the sensor does not. My guess is that the input pins need to be readdressed but I am unsure how to do this and then combine it all into one sketch. When I try I get errors
Here is the code I am trying to mash together
and the errors
sketch_sep04a.ino: In function 'void loop()':
sketch_sep04a:163: error: redefinition of 'void loop()'
sketch_sep04a:120: error: 'void loop()' previously defined here
I realize there is a previously defined "void loop" but am unsure of the naming conventions to redefine it. When I try it generates other errors.
Thanks.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_TSL2561_U.h>
/* This driver uses the Adafruit unified sensor library (Adafruit_Sensor),
which provides a common 'type' for sensor data and some helper functions.
To use this driver you will also need to download the Adafruit_Sensor
library and include it in your libraries folder.
You should also assign a unique ID to this sensor for use with
the Adafruit Sensor API so that you can identify this particular
sensor in any data logs, etc. To assign a unique ID, simply
provide an appropriate value in the constructor below (12345
is used by default in this example).
Connections
Connect SCL to analog 5
Connect SDA to analog 4
Connect VDD to 3.3V DC
Connect GROUND to common ground
I2C Address
The address will be different depending on whether you leave
the ADDR pin floating (addr 0x39), or tie it to ground or vcc.
The default addess is 0x39, which assumes the ADDR pin is floating
(not connected to anything). If you set the ADDR pin high
or low, use TSL2561_ADDR_HIGH (0x49) or TSL2561_ADDR_LOW
(0x29) respectively.
History
2013/JAN/31 - First version (KTOWN)
Adafruit_TSL2561_Unified tsl = Adafruit_TSL2561_Unified(TSL2561_ADDR_FLOAT, 12345);
Displays some basic information on this sensor from the unified
sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
sensor_t sensor;
tsl.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" lux");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" lux");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" lux");
Serial.println("");
delay(500);
Configures the gain and integration time for the TSL2561
void configureSensor(void)
/* You can also manually set the gain or enable auto-gain support */
// tsl.setGain(TSL2561_GAIN_1X); /* No gain ... use in bright light to avoid sensor saturation */
// tsl.setGain(TSL2561_GAIN_16X); /* 16x gain ... use in low light to boost sensitivity */
tsl.enableAutoRange(true); /* Auto-gain ... switches automatically between 1x and 16x */
/* Changing the integration time gives you better sensor resolution (402ms = 16-bit data) */
tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_13MS); /* fast but low resolution */
// tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_101MS); /* medium resolution and speed */
// tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_402MS); /* 16-bit data but slowest conversions */
/* Update these values depending on what you've set above! */
Serial.print ("Gain: "); Serial.println("Auto");
Serial.print ("Timing: "); Serial.println("13 ms");
Arduino setup function (automatically called at startup)
void setup(void)
Serial.println("Light Sensor Test"); Serial.println("");
/* Initialise the sensor */
if(!tsl.begin())
/* There was a problem detecting the ADXL345 ... check your connections */
Serial.print("Ooops, no TSL2561 detected ... Check your wiring or I2C ADDR!");
while(1);
/* Display some basic information on this sensor */
displaySensorDetails();
/* Setup the sensor gain and integration time */
configureSensor();
/* We're ready to go! */
Serial.println("");
Arduino loop function, called once 'setup' is complete (your own code
should go here)
void loop(void)
/* Get a new sensor event */
sensors_event_t event;
tsl.getEvent(&event);
/* Display the results (light is measured in lux) */
if (event.light)
Serial.print(event.light); Serial.println(" lux");
else
/* If event.light = 0 lux the sensor is probably saturated
and no reliable data could be generated! */
Serial.println("Sensor overload");
delay(250);
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// Some example procedures showing how to display to the pixels:
colorWipe(strip.Color(255, 0, 0), 50); // Red
colorWipe(strip.Color(0, 255, 0), 50); // Green
colorWipe(strip.Color(0, 0, 255), 50); // Blue
// Send a theater pixel chase in...
theaterChase(strip.Color(127, 127, 127), 50); // White
theaterChase(strip.Color(127, 0, 0), 50); // Red
theaterChase(strip.Color( 0, 0, 127), 50); // Blue
rainbow(20);
rainbowCycle(20);
theaterChaseRainbow(50);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
for (int j=0; j<10; j++) { //do 10 cycles of chasing
for (int q=0; q < 3; q++) {
for (int i=0; i < strip.numPixels(); i=i+3) {
strip.setPixelColor(i+q, c); //turn every third pixel on
strip.show();
delay(wait);
strip.setPixelColor(i+q, 0); //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
for (int j=0; j < 256; j++) { // cycle all 256 colors in the wheel
strip.setPixelColor(i+q, Wheel( (i+j) % 255)); //turn every third pixel on
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
Thanks.
You can have only one setup() and only one loop(). If you want to combine the code, take the code from one loop and add it to the other.I realize there is a previously defined "void loop" but am unsure of the naming conventions to redefine it. When I try it generates other errors.
- edwardiglesias
Well I got the thing so it does not generate an error
The leds light up but the sensor does not show up on the serial monitor.
#include <Wire.h>
#define PIN 6
//adding sensor
sensor_t sensor;
Serial.println("");
delay(500);
strip.begin();
if(!tsl.begin())
while(1);
configureSensor();
Serial.println("");
rainbow(20);
rainbowCycle(20);
if (event.light)
else
delay(250);
strip.show();
delay(wait);
uint16_t i, j;
strip.show();
delay(wait);
uint16_t i, j;
strip.show();
delay(wait);
strip.show();
delay(wait);
strip.show();
delay(wait);
if(WheelPos < 85) {
WheelPos -= 85;
} else {
WheelPos -= 170;
Are the leds doing the expected things (color wipe, theater chase etc)?The leds light up but the sensor does not show up on the serial monitor.
As written, the sensor output will not be written to the serial monitor until all of the led sequences have completed.
- edwardiglesias
They are but I may have been impatient. I didn't wait for everything to cycle through.
- edwardiglesias
I WAS impatient. Just got
Sensor: TSL2561
Driver Ver: 1
Unique ID: 12345
Max Value: 17000.00 lux
Min Value: 0.00 lux
Resolution: 1.00 lux
Gain: Auto
Timing: 13 ms
on the serial monitor. Thanks so much!!
Sensor: TSL2561
Driver Ver: 1
Unique ID: 12345
Min Value: 0.00 lux
Gain: Auto
Timing: 13 ms
You are welcome!
